ELECTRONIC VSS,WHERE SHOULD WIRE GO
Old Nov 7, 2005 | 06:51 PM
yellowjdmcrx's Avatar
Default ELECTRONIC VSS,WHERE SHOULD WIRE GO
hey guys man i have been messen with this stuff for awhile now. i need to knw if i shouyld cut the wire to the ecu or just splice into it? please someone help i am tired of the check engine light.
thanks guys
Old Nov 8, 2005 | 03:18 PM
Default Re: ELECTRONIC VSS,WHERE SHOULD WIRE GO (yellowjdmcrx)
bump please
Old Nov 8, 2005 | 03:43 PM
90civichbsi's Avatar
you can just run it either too the wire at the ecu or by the cluster itself, just splice it in. if you didnt already know its the yellow/red wire
Old Nov 8, 2005 | 05:58 PM
Default Re: ELECTRONIC VSS,WHERE SHOULD WIRE GO (90civichbsi)
if i dont run the wire to the ecu then the check engine light comes on,so it is cool to just run it straight to the ecu and cut the wire from the ecu off and put the one for the vss in there
Old Nov 8, 2005 | 07:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowjdmcrx &raquo;</TD></TR><TR><TD CLASS="quote">if i dont run the wire to the ecu then the check engine light comes on,so it is cool to just run it straight to the ecu and cut the wire from the ecu off and put the one for the vss in there</TD></TR></TABLE>
are you trying to run a sir cluster or what?
im not sure if i get what your saying, both your ecu and cluster need the signal. the cluster needs it for obvious reasons (to tell you the speed). when you run it to the ecu it will get rid of the check engine light.
what i was saying is that the stock yellow/red wire runs from the ecu to the cluster so if you just run a wire from the VSS and splice it into that wire it will send a signal to both the ecu and cluster (assuming you have the cluster wired up correctly.
Old Nov 8, 2005 | 07:53 PM
dude i have a 99 si cluster, i just need to run the wire to my ecu then
Old Nov 9, 2005 | 04:02 AM
VegaS10's Avatar
I have a gsr cluster in my 89 crx si and have a similar problem. I got the cluster to work great, but, the yellow/red wire is in pin b18 on my ecu and I'm scared to hook it up....
Old Nov 9, 2005 | 12:34 PM
Rukusmasta2's Avatar
Default Re: (VegaS10)
SEARCH IS UR BUDDY https://honda-tech.com/zerothread?id=709958
Old Nov 9, 2005 | 12:59 PM
VegaS10's Avatar
Default Re: (Rukusmasta2)
I got that.
Pin B16 in my ecu is empty, Pin B18 is yellow/red.....
Old Nov 9, 2005 | 05:46 PM
i think that is the same way mine is,i will look at it tomarrow and see
Old Nov 9, 2005 | 06:11 PM
VegaS10's Avatar
Default Re: (yellowjdmcrx)
let me know. I'm tired of seeing that damn light knowing what is wrong.
(mine is an 89 si as well...)
Old Nov 9, 2005 | 06:13 PM
Stoich's Avatar
lol same problem everything works except the speedo and i followed the write up
wrong wires i guess
Old Nov 9, 2005 | 06:19 PM
VegaS10's Avatar
Default Re: (Stoich)
My cluster has worked fine for months, just the ecu doe'snt have a vss signal. I got the wire, just don't know which pin on the ecu to put it into.
Old Nov 9, 2005 | 06:48 PM
my speedo works i just have a check engine light
Old Nov 20, 2005 | 03:05 PM
finaly,i got everything on my cluster workin and no check engine light.
Old Nov 20, 2005 | 04:15 PM
VegaS10's Avatar
what was it?
Old Nov 20, 2005 | 04:22 PM
i had to splice off of the wire ran to the cluster from the vss and run it to bin b18 on my 89 might be diff on ur car but it is the yellow and red wire just look for that and then cut it and hook that wire up.
Old Nov 21, 2005 | 02:57 AM
VegaS10's Avatar
I'll be trying that today...
bcumbie
Engine Management and Tuning
Mar 16, 2012 08:49 PM
BlueShadow
Jun 1, 2005 10:08 PM
jtracing919
Jan 11, 2005 06:45 AM
dingusjt
Nov 13, 2003 10:18 AM
b20_ed
Jul 14, 2003 10:34 AM
