once apon a time i had a cold air intake and drove through a puddle now i need help!!!
Old Nov 7, 2005 | 06:26 PM
slowazz92akkord's Avatar
Default ************once apon a time i had a cold air intake and drove through a puddle now i need help!!!
once apon a time i drove my 93 ex through a puddle... it had a cold air intake... u kno the rest...
i found another block will it work???
old block... d16z6
new one from an 88 civic dx... (68k miles)
will everything match up??
a friend said everything will
Old Nov 7, 2005 | 06:28 PM
mike93eh
Guest
Posts: n/a
the 88 engine is obd0. d16z6 is obd1. why are you putting a 88 dx engine in a 93 ex anyways? you cant find a z6 or hell a b7 lying around anywhere?
Slimm-rw-'s Avatar
I'm a Jackass
Default Re: ************once apon a time i had a cold air intake and drove through a puddle now i need help!
yeah, it'll work, but its not obd1, and its a 1.5...I'd keep searching
Old Nov 8, 2005 | 07:41 AM
well if i put an integra ls engine in it will it all match up? i know id have to get the ecu n all that **** with it but will all the linkage match up... motor mounts... etc...?
anyone got a d16z6 block layin around???
or a ls long block with tranny??
Old Nov 8, 2005 | 07:46 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slimm-rw- &raquo;</TD></TR><TR><TD CLASS="quote">yeah, it'll work, but its not obd1, and its a 1.5...I'd keep searching</TD></TR></TABLE>
Exactly.
Old Nov 8, 2005 | 07:54 AM
mwieczorek43's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowazz92akkord &raquo;</TD></TR><TR><TD CLASS="quote">once apon a time i drove my 93 ex through a puddle... it had a cold air intake... u kno the rest...</TD></TR></TABLE>
What kind of insurance do you have?
I got a brand-new LS from my insurance (State Farm) b/c I had full-coverage, and the motor is covered by 'water-damage' b/c of the comprehension part.
Might want to call your agent and ask (and take off the CIA).
edit- Well, not 'brand' new...... 25k new.
Old Nov 8, 2005 | 08:19 AM
LShatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">What kind of insurance do you have?
edit- Well, not 'brand' new...... 25k new.</TD></TR></TABLE>
did they just give you a check and you went out and found your own?
Old Nov 8, 2005 | 08:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie &raquo;</TD></TR><TR><TD CLASS="quote">did they just give you a check and you went out and found your own? </TD></TR></TABLE>
Yes. I took it to a shop (my buddies). He wrote-up an estimate for a brand-new z6 (that's what blew-up), and the insurance-guy wrote a check. I took the money for a brand-new z6 and bought a slightly-used LS instead.
Old Nov 8, 2005 | 10:29 AM
i just had liability... just enough to get it on the road...
still need a block ppl!
Old Nov 9, 2005 | 06:42 AM
any1 with a block?
bump cuz i still need one
Old Nov 9, 2005 | 06:50 AM
eg2wes's Avatar
what size "puddle" did you go through?? good lord. check out soko america 420 bucks shipped for a d15b sohc vtec it will work better than your z6
Old Nov 9, 2005 | 12:42 PM
Default Re: (eg2wes)
here in syracuse when it rains it usually poors... i didnt realize it was so deap... id say prolly 6inches to a foot? prolly more like 6.
Old Nov 10, 2005 | 01:55 PM
Default Re: (slowazz92akkord)
Old Nov 10, 2005 | 03:09 PM
spoonracer84eg's Avatar
Assuming your engine hydro locked... Did you even look to see if there was any damage (bent valves etc...). I was told to pull spark plugs out and turn the crankshaft backwards to push the water out. Not 100% about it though.
Old Nov 10, 2005 | 03:59 PM
i wish it just hydro locked... it sucked in water... which blew the engine... idk exactially what it did but it blew a hole in the block... theres literally a hole in the block wall which pretty much ran the engine without oil... it happend so fast i didnt have time to cut the car off... no bent valves... the only way that would happen is if the timing belt broke. in other words... the water cooled the aluminum block unevenly... which caused it to crack the aluminum. not a good thing i must say! the oil is under about 60lbs of pressure or more which blew pretty much all of the oil outta the engine at once...
still need a block tho!
Old Nov 11, 2005 | 10:20 AM
Old Nov 11, 2005 | 09:00 PM
another freeeeeekin bump cuz i need a block!!!
Old Nov 13, 2005 | 02:57 PM
Old Nov 13, 2005 | 06:42 PM
bump b4 bed
Old Nov 14, 2005 | 02:30 PM
bumppppppp
ppl help a fellow ricer out
ill take anything thatll work!
gotta b a 1.6 tho
Old Nov 14, 2005 | 02:33 PM
mike93eh
Guest
Posts: n/a
http://www.hmotorsonline.com/s...30019
Old Nov 14, 2005 | 05:05 PM
i just need the block and pistons n stuff... no long block no tranny no nothin i have all that good stuff...
Old Nov 14, 2005 | 05:29 PM
mike93eh
Guest
Posts: n/a
i have just the block if you want it. im parting the engine out.
Old Nov 15, 2005 | 07:39 AM
Default Re: (mike93eh)
are the pistons and crank n all that good stuff in there?
Old Nov 15, 2005 | 08:00 AM
JDM-Punk's Avatar
i have a d16 in my del sol that im about to do a engine swap to a b16a and will have no use for the d anymore... it has 100k miles but runs great if ya want it
