crx k20a2 turbo clearance problem
Huh I am wondering about the crx, if you put a k20a2 in it with hasport engine mount and then put a turbo will i have heat problem or clearance probleme with the firewall or i'll be fine ?!
The clearance is very tight, if there is someone out there that has done this, i'll be shocked.
F-A-B-R-I-C-A-T-I-O-N
Really, cut the firewall behind the exhaust out and move it all back about a foot. Plenty of room for a turbo then
Heat problem would be, downpipe too close to the fuel filter if you left it in the stock location.
Otherwise... the firewall can take some heat, if course you don't want anything within an inch of the header/downpipe
What we're really all thinking is : "if you have to ask... YOU can't do it."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai »</TD></TR><TR><TD CLASS="quote">The clearance is very tight, if there is someone out there that has done this, i'll be shocked.
F-A-B-R-I-C-A-T-I-O-N </TD></TR></TABLE>
ditto...just takes a little patience and a lot of time.
im sure it can be done. some one can mounted a turbo 3' above a crx hood and made it work....call him
who says the turbo has to be in that location?
yeah i saw this one pretty stupid for a setup!!!
So without cutting the firewall it could really be a tight fit !! and what about if i buy a civic si 02-05 turbo kit and try to fit it would it work or will i have to do some cutting ?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai »</TD></TR><TR><TD CLASS="quote">F-A-B-R-I-C-A-T-I-O-N
when I saw this i started singing
M-I-C-K-E-Y M-O-U-S-E
I am a dork
</TD></TR></TABLE>when I saw this i started singing
I am a dork
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">when I saw this i started singing
I am a dork
HAHAHAHAHA me too
I am a dork
</TD></TR></TABLE>HAHAHAHAHA me too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonModel »</TD></TR><TR><TD CLASS="quote">why is no one suportive</TD></TR></TABLE>
If you are seriously going to do this we will support you. It is going to take alot of money, alot of time, and a welder and good skills. There's a thread active in this forum about a guy's k20 crx, start reading there. I just know that it's not ANYTHING like swapping a D or a B series, which is why I am not doing it in the near future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonModel »</TD></TR><TR><TD CLASS="quote">why is no one suportive</TD></TR></TABLE>Because this is honda tech.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91B16HF »</TD></TR><TR><TD CLASS="quote">Because this is honda tech.</TD></TR></TABLE>
LOL
What we're really all thinking is : "if you have to ask... YOU can't do it."</TD></TR></TABLE>
That's usually what happens around here. Not many people are capable or have the tools to do this. This is not a personal insult to you or anything.
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotommy »</TD></TR><TR><TD CLASS="quote">who says the turbo has to be in that location?</TD></TR></TABLE>
i like the way you think. your imagination is the limit when it comes to something this complex. I'm sure you could mount the turbo on the RIGHT side of the engine bay since there is a gaping hole when you do a k swap.. Just be creative. Look at pics of turbo eks or egs with k swap and get some idea where you can put it.
It can and has been done, if you want my advice putting a K series into an EF and turboing it is a waste of time and money, B series is much cheaper and simpler for forced induction, especially into the EF chassis
I thought my responce was helpful LOL
Check k20a.org
they may help more
By the way, i'm shocked - k20a.org has a k20 turbo crx member... wow.
Check k20a.org
they may help moreBy the way, i'm shocked - k20a.org has a k20 turbo crx member... wow.
I am a dork </TD></TR></TABLE>
Your not right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonModel »</TD></TR><TR><TD CLASS="quote">why is no one supportive</TD></TR></TABLE>
I think everyone was being fairly helpful. If you want someone to be a dick then just post something stupid and we'll all crawl out of the nooks and crannies like roaches and flame on you.
I would also say you could do the turbo at the rear of the car and then pipe it back to the front if room is an issue. You will lose a little PSI but you can have your turbo. Also someone said something about heat and the fuel filter which I 100% agree with so to keep heat down you could get your stuff ceramic coated which would help alleviate the heat problem. I know lots of guys that ceramic coat the turbos on there diesels. I think a K20 turbo could be done but you will have to take your time THINK OUTSIDE OF THE BOX and make what will work for your car. Otherwise B-series turbo and for the money you are going to spend, dump that into a B-series turbo setup and you will have something that screams.
Just my .03
Your not right.
Just my .03
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tangerinebeast »</TD></TR><TR><TD CLASS="quote">guy in cincinnati ohio has a k20 crx which is pictured in spoonmodel avitar and it was slow as **** because of itz high compression and turbod the stock motor</TD></TR></TABLE>
what in the expletive are you talking about?
look guy, ryan of rywire just finished his k20 swap.
ask him to stick a tape measure back there, and you'll get an idea of how much room you have.
from the images i have seen, i would say very little.
if you have NO room, then youll need to 'massage' the firewall with a hammer, or just take a jigsaw to the whole damn thing, now if you had planned on driving this on the street its going to get NASA rocket style hot in the cockpit if you do that.
if you find a turbo small enough to fit, heat will still be an issue. just ask any turbo MR2 owner about heatsoak.
to compensate you would need a hood cowl, or some sort of serious air flow behind the block to keep it cool.
so sleeper is right out. but if you atempt it, id give you props. if you make an eleborate piping system to relocate the turbo that COULD work, but thats a shitload of fabrication considering theres so much aftermarket support for LS internals (in other words, just use a b20 block)
but if you want it for that 6th gear i can give you that, either way, good luck.
How about a remote mount turbo setup?
You could use a huge turbo, and wouldn't have to worry about any clearance issues at all...
Plus, in a CRX there is plenty of room in the back for a turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">How about a remote mount turbo setup?
Plus, in a CRX there is plenty of room in the back for a turbo. </TD></TR></TABLE>
those "muffler turbo" setups are inneficient and require a great deal of custom fabrication. you need charge piping running the length of the car, an oil feed and return system with an inline pump and a custom manifold.
we need pics!
we need pics!
