Welding Project for SKOOL is Engine Hoist. Any suggestions?
Old Nov 7, 2005 | 05:30 PM
Mooneyes13's Avatar
Default Welding Project for SKOOL is Engine Hoist. Any suggestions?
more updates soon w/ newly added supports
Modified by Mooneyes13 at 3:00 AM 12/4/2005
Old Nov 8, 2005 | 06:25 AM
beepy's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (Mooneyes13)
Engine hoists are pretty well-engineered already. Just take a look at one and copy it, trying to make it more collapsible.
A worthwhile project might be to make an engine hoist that can be used to pull the engine out of a full-size van. Have you ever tried to use a regular cherry-picker in a van? PITA. It would need to have a very long arm, and a narrow yet stable base.
Another idea might be an engine hoist that can be used on dirt or gravel safely. You know, for white trash like me that don't always have a concrete slab to work on.
Old Nov 8, 2005 | 07:10 AM
JDMrps13's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (beepy)
^^^ bahah he is right though....something that you can use on dirt and gravel and etc would be innovative
Old Nov 10, 2005 | 07:02 AM
Mooneyes13's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (JDMrps13)
so far.....
This hoist will be able to break into 3 pieces. Base, Upright, Arm
Next is to decide on wheels and Ram.
New pix.
Coming Along.
more
Modified by Mooneyes13 at 12:59 AM 11/18/2005
Old Nov 10, 2005 | 08:25 AM
JK_Motorsports's Avatar
Make it Collaspable!!! I know that is one of the greatest features on our. Saves a bunch of space when not in use!!!!!
Old Nov 10, 2005 | 08:36 AM
Mooneyes13's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (bumblezc)
Yes, i noted it will break into three pieces.
Old Nov 10, 2005 | 10:27 AM
khoalie's Avatar
ours breaks into 5 pieces, the legs fold up
Old Nov 14, 2005 | 01:55 PM
Mooneyes13's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (khoalie)
new pix
Old Nov 14, 2005 | 02:17 PM
RCautoworks's Avatar
Looks good
Old Nov 16, 2005 | 10:03 PM
VRD^sam's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (90blackcrx)
alot of work but looking good...
Old Nov 18, 2005 | 06:04 AM
Mooneyes13's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (boostin_elf)
new pix
Old Nov 30, 2005 | 12:26 PM
Mooneyes13's Avatar
new pix
Old Nov 30, 2005 | 01:27 PM
Atheist's Avatar
http://img.photobucket.com/alb...2.jpg
Inner weld looks kind of crappy there, how much benetration are you getting?
Old Dec 1, 2005 | 01:02 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mooneyes13 &raquo;</TD></TR><TR><TD CLASS="quote">Welding Project for SKOOL is Engine Hoist. Any suggestions??
The weak spot is at the base of the vertical upright. The weld to the baseplate on the backside is going to be under tension when the arm is under load. I would of leaned the vertical back away from the hook and added some braces down to the legs. Like this one, for example:
Old Dec 1, 2005 | 04:39 PM
Hmm I would be worrying about it tipping backwards. In the picture the arm is not really that high, it will have to go higher to clear the bumper and what not.
Old Dec 1, 2005 | 07:55 PM
Mooneyes13's Avatar
we'll see how it works. i also have added some extra supports.
Old Dec 1, 2005 | 09:41 PM
.RTErnie's Avatar
your moment about the lower mounting point of the hydrualic ram is too far to the back of the hoist. Your **** will tip over. if you move your lift arm closer to the hydraulic pump you may be able to help it balance. good luck!
Old Dec 2, 2005 | 12:41 AM
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">your moment about the lower mounting point of the hydrualic ram is too far to the back of the hoist. Your **** will tip over. if you move your lift arm closer to the hydraulic pump you may be able to help it balance. good luck! </TD></TR></TABLE>
Thats what I was thinking, and that can't be good.
Old Dec 2, 2005 | 07:04 AM
SQ is the SQUAD's Avatar
you should make a lift that is designes to lift a civic front by the tow hooks so that we can remove the engine from the bottom (pull out the side wheel well)
Old Dec 3, 2005 | 02:59 PM
CRVRX's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (h0ndavtec)
Here's an Idea for ya.
Make the hoist have a place to bolt the engine block too, ( Engine stand) .
One less thing taking up room in the shop, It's hard to make a hoist stand out when there's tons of them out there.
Like someone said , Make it fold up to take up less Sq Ft, That would would be cool.
And , Yes the base is the week point, plus too much weight at the back end.
Good luck!
Old Dec 3, 2005 | 03:19 PM
743power's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">Here's an Idea for ya.
Good luck!</TD></TR></TABLE>
that has been done already. . .
i will 3rd the weak base. i one time left the extra supports off my stand and it ripped the base right off.
Old Dec 3, 2005 | 11:57 PM
Mooneyes13's Avatar
Default Re: Welding Project for SKOOL is Engine Hoist. Any suggestions? (743power)
**** people, i added more supports, chill ur roll, new pix soon.
Also had 300 pound football player hang from it
Old Dec 4, 2005 | 01:10 AM
Eddiebx's Avatar
i dont really think its a matter of supporting it, its about the design. **** looks like it will flip over if you lift the load high enough to clear the radiator support.
Old Dec 8, 2005 | 04:02 PM
vtecmissle's Avatar
design one that doesnt shift the motor towards the stand when you pump it up. Some kind of compound action so the engine goes straigtht up unstead of forwards
Old Dec 9, 2005 | 11:06 AM
M@'s Avatar
M@
Default Re: (vtecmissle)
or just make longer legs
