F20B rev limiter
Old Nov 7, 2005 | 05:00 PM
jetlude's Avatar
Default F20B rev limiter
Does anyone know what the F20B limit at? and what ecu it uses?
Old Nov 10, 2005 | 01:29 PM
CD7-F20B's Avatar
Default Re: F20B rev limiter (bradboy)
po5 is mine 99 sir-t
Old Nov 10, 2005 | 06:59 PM
JDogg's Avatar
Default Re: F20B rev limiter (CD7-F20B)
the redline on the stock accord sirt tach is at 7200rpms. mine came with a pcb ( i think) ecu
Old Nov 12, 2005 | 12:07 AM
jetlude's Avatar
I mean where does the ecu actually cut the revs. On mine it cut off at about 7800. Is this right? I thought it should rev to 8000
Old Nov 12, 2005 | 11:59 AM
JDogg's Avatar
Default Re: (bradboy)
keep in mind your stock tach is hardly ever right.
but f20b's dont rev that high from the factory. every sir cluster i have see has the redline at 7200, so id immagine the limiter was at 74 or 7500
Old Dec 5, 2005 | 12:31 AM
chuckles2's Avatar
Default Re: (JDogg)
limiter is set at 7800rpm but you can safely rev to 8200 and they are stil making to then aswell.
Old Oct 14, 2010 | 02:41 PM
f2beastcivic's Avatar
i have a 94 eg with a 99 f20b swap with a chipped p30 ecu i have reved up to 8500 rpms its loud and pulls extreamlly hard from 6000 on. i see videos on youtube of the f20 hitting 9000rpm but im not tryin it.
Old Apr 19, 2011 | 03:39 PM
93accordsleeper's Avatar
my wife is running a obd2 H22a with a F23 odyssey auto tranny using the auto PCB ecu and it shifts at 7800rpms!! its kinda funny it hits rev limit a split sec before it shifts, ****in thing pulls hard tho for a auto
98greensi
Mar 5, 2012 04:07 PM
tenchi r
Mar 6, 2010 10:45 AM
kyle48_2007
Feb 6, 2010 10:31 PM
