bogging
Old Mar 9, 2002 | 07:17 PM
mafioso102's Avatar
New User
Default bogging
just got a b16 swapped in a couple weeks ago, and earlier this week i noticed that when i accelerate off in first, it boggs until 1800 rpms. Any suggestions?
Old Mar 9, 2002 | 07:27 PM
CRXtc 90's Avatar
Default Re: bogging (mafioso102)
did u adjust your valves
Old Mar 9, 2002 | 07:36 PM
mafioso102's Avatar
New User
Default Re: bogging (CRXtc 90)
after the swap, yup
Old Mar 9, 2002 | 08:51 PM
Stinkalope's Avatar
New User
I have been chasing my bogging problems for months, I decided (after replacing every other part on the car) now that I have broken vavle springs and it is not opening and closing some of the valves correctly. O2 sensors seem to be pretty common problems though...
Old Mar 9, 2002 | 08:54 PM
Mugen Dom's Avatar
Default Re: bogging (Stinkalope)
either of u try a new fpr used or wutever
Old Mar 9, 2002 | 09:32 PM
Veil_Side_'s Avatar
Default Re: bogging (jdmB18hatch)
could be electrical
check compression
check fuel filter and fuel lines for clogs and stuff
check catalytic converter, maybe clogged when you did the swap.
check 02 sensor
thats all I can think of for now
Old Mar 10, 2002 | 06:04 AM
Stinkalope's Avatar
New User
Default Re: bogging (Veil_Side_)
jdmb18hatch...already changed it thanks, Veil_side...I check all electrical I could think of replaced cap, rotor, coil, ignitor (it went bad anyway), plugs, wires, etc., compression is 200 across the board, new fuel filter and lines flushed a few times, cat is gutted, and two brand new Bosch O2 sensors...Thanks though
Old Mar 11, 2002 | 06:04 PM
GSRacer's Avatar
New User
i just swaped a motor in also and i'm having the same problem. anyone?
Old Mar 11, 2002 | 08:55 PM
EF'n Fast's Avatar
Default Re: bogging (GSRacer)
kinda stupid to bring up...but just a reminder...
got new spark plugs + wires + oil + belts + water pump right?
Old Mar 12, 2002 | 04:13 AM
GSRacer's Avatar
New User
Default Re: bogging (EF'n Fast)
yeah, went through all of that already
Old Mar 12, 2002 | 05:58 AM
Stinkalope's Avatar
New User
yeah, me too, anything else??
Old Mar 12, 2002 | 09:21 AM
GSRacer's Avatar
New User
some people are telling me to get my valves adjusted.
Old Mar 12, 2002 | 09:33 AM
Doodoo's Avatar
Another simple one, are all your grounds connected? I know for sure there should be 3, I have heard 4 though. Just a thought.
Old Mar 13, 2002 | 02:49 PM
iwhichisme's Avatar
would that cause bogging, my car doesnt bog but is slow as ****, and dont know why. I think i might have auto cams in it. Watcha think?
Old Mar 13, 2002 | 02:53 PM
iwhichisme's Avatar
if youre runnig two o2 sensors, unplug them both and see how it works. If that stops the bogging just flip either the o2 sensors or (the wires for the o2 sensors at the ecu). It worked like a charm for me.
Old Mar 13, 2002 | 09:09 PM
Frcfedintegra's Avatar
have you checked your fuel pressure? your stock pump may not be giving you enough. i swapped my pump out for an h22a pump.
Old Mar 14, 2002 | 07:16 AM
Stinkalope's Avatar
New User
Default Re: bogging (CivlizdSir)
I will check the pressure this weekend, but once it hits higher revs its fine. I would imagine that the car would starve up top also and not just on the bottom end right??
Old Mar 14, 2002 | 09:26 AM
Bs's Avatar
Bs
Did you adjust the timing?
Old Mar 14, 2002 | 01:25 PM
Stinkalope's Avatar
New User
Default Re: bogging (B_s)
I have adjusted the timing and idle at least twice to look for a difference. Anything else.......
Old Mar 14, 2002 | 07:35 PM
Mugen Dom's Avatar
it sounds like fuel delivery to tell u the truth. maybe ur pump is on the way out. but be sure u have good fuel pressure. it could be clogged injecters to have u checked them?
Old Mar 18, 2002 | 04:34 PM
handiman15's Avatar
Default Re: bogging (iwhichisme)
mine is doing the same, so i just take the o2 sensors off? wouldn' tthat throw up codes? then put them on backwards?
eg6sir88
Jan 31, 2014 11:16 AM
coco718
13
Oct 5, 2011 02:27 PM
whiteformula98
10
Dec 26, 2008 09:15 AM
99blackdc2
Oct 28, 2006 08:40 PM
ludewithanh22
Apr 27, 2005 10:57 AM
