Clutch Seal
Old Nov 7, 2005 | 02:16 PM
eldorko86's Avatar
Default Clutch Seal
How do i do it? how much, and HELP!
Old Nov 7, 2005 | 02:25 PM
dropcivic's Avatar
Default Re: Clutch Seal (eldorko86)
clutch seal? I am so lost. Do you mean the rear main seal back behind the fylwheel?
Old Nov 7, 2005 | 03:01 PM
nocturnaldragon's Avatar
If its the main shaft seal on the engine or the input shaft seal on the transmission its basicly the same process. If you look up a how to on how to replace your clutch that will help.
Basicly what you need to do tho is remove the transmission, once its removed, if its the seal on the motor you need to remove the pressureplate and clutch, and flywheel I belive. Get a seal puller (Rent one from AutoZone) or a flat head screw driver and pull it out and install the new OEM HONDA SEAL in its place with the special tool (Also available from autozone) or a large enough socket. If its the one on the transmission its a lot more work because you have to disasemble the transmission to do it. Look up the write up from BaulyCivic on how to replace your mainshaft bearing.
Hope that helps you out.
Old Nov 7, 2005 | 03:15 PM
eldorko86's Avatar
Default Re: Clutch Seal (nocturnaldragon)
can you do it yourself?
Old Nov 7, 2005 | 03:18 PM
eldorko86's Avatar
or if i took it to someone how much?
mattbatson
20
Mar 25, 2012 05:09 PM
90civSi
21
Feb 8, 2006 04:52 PM
maxogsr
Jun 22, 2005 06:46 PM
ablack934doorcivic
Jun 11, 2004 02:14 PM
ALF
Feb 13, 2003 04:21 AM
