Transmission troubles???
Old Nov 7, 2005 | 01:32 PM
4NOWJUSTADX's Avatar
Default Transmission troubles???
i replaced the clutch a few days ago because there was a whirring sound coming from the transmission area. i went by a few shops and they all swore it was the throw out bearing. one mechanic said it was a main shaft bearing and a new trransmission is needed, but after i put the new one in the same sound exists. the sound goes away while the clutch is in, but gets louder with rpm and is very very loud on downshifts (which i have stopped doing in fear of breaking something). Has anyone had a similiar problem or any clue what may be going on with it?
Old Nov 7, 2005 | 02:16 PM
kkim's Avatar
Default Re: Transmission troubles??? (4NOWJUSTADX)
I'm troubleshooting the same problem. It sounds like, from what I've read, most likely the input shaft bearing. Is that what was changed in yours?
Old Nov 7, 2005 | 02:26 PM
Default Re: Transmission troubles??? (kkim)
I changed the release (throw out) bearing and while i was there the disk and pressure plate. i didnt even think to look at the input shaft bearing. i have to take it all apart again so i will see what kind of shape it is in.
Old Nov 7, 2005 | 02:33 PM
kkim's Avatar
Seems to be a common D series trans problem.
https://honda-tech.com/zerothread?id=596873
Old Nov 7, 2005 | 03:05 PM
nocturnaldragon's Avatar
Theres a good write up from Bauly Civic on how to do this, its pretty simple to do once you get the transmission apart. Ive done about 10 of these now, takes me an hr once the transmission hits my work bench. Get OEM HONDA BOND tho to re-seal the transmission back up, Ive ussed the cheap **** from autozone and it was just that cheap **** the whole case leaked and had to be taken out again and resealed properly.
A helpfull trick is to use a flatt head screw driver to push the old bearing out and a large socket to push the new one in. You want to hit the outside of it NOT the ball bearings or the inner race or you'll mess that one up as well.
Old Nov 8, 2005 | 03:39 PM
Default Re: Transmission troubles??? (nocturnaldragon)
does anyone have or know of a good diagram of the transmission? i would love to study it out a little before just diving into it? i have a haynes manual but didnt see anything on the input shaft bearing. thanks for the help
Old Nov 8, 2005 | 04:23 PM
kkim's Avatar
get a helms manual.
KHaoTiK
12
Feb 23, 2010 02:29 PM
superfast666
Jun 6, 2008 10:41 AM
1kleenef
Apr 13, 2008 11:12 AM
aznrexboi00
21
Oct 1, 2005 09:02 AM
jfrye
14
Apr 26, 2005 03:57 AM
