HELP Installing Apexi Rev Speed Meter and G Sensor *SEARCHED*
You cant search for G sensor as the G wont be accepted and I cant find any answers on how to install this. Can anyone link me or explain to me how to install the G sensor on a 6th gen coupe. Also, I followed the basic wiring install for the RSM (IG power, Ground, Speed, and RPM) are any of the other wires used?
Anyone?
Anyone?
Called Apexi and they told me everything I needed to know.
3 wires on G Sensor are NOT used. Plugs directly into the bottom of the RSM. Use double sided tape on ANY flat surface in the car to mount the G Sensor. I did it between the carpet and the hole in the chassis for the shifter (under the center console). For 6th gen coupe you only use the four wire install to the harness. Red, Black, Yellow, Purple.
fastyouth1313
Dec 4, 2006 10:41 PM
