Suspension & Brakes Theory, alignment, spring rates....
for all you ground control and kyb agx people..
Old Nov 7, 2005 | 10:55 AM
solsi2000's Avatar
Default for all you ground control and kyb agx people..
hi i bought my setup off here from someone that had ground controls with kyb agxs on his hatch. his hatch was perfectly level. well i got them a few months back and had some friends help with the install onto my 93 del sol and i believe that they are installed wrong. the front coilovers are raised as much as they can go and the front still looks pretty low. as for the rear its the opposite. the rear coilovers are lowered as much as they can go and the back height looks almost stock. So do the rears need to go in the front and the fronts in the rear? also i was told the rear struts wouldnt fit on the front is this true? thanks for trying to figure this out.
Old Nov 7, 2005 | 12:00 PM
AutoXer's Avatar
Default Re: for all you ground control and kyb agx people.. (solsi2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsi2000 &raquo;</TD></TR><TR><TD CLASS="quote"> well i got them a few months back and had some friends help with the install onto my 93 del sol and i believe that they are installed wrong.</TD></TR></TABLE>
Are they custom rates / lenghts? What are the numbers on the springs? I beleive the OTS rates come with different lenght sleeves and springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsi2000 &raquo;</TD></TR><TR><TD CLASS="quote">also i was told the rear struts wouldnt fit on the front is this true? thanks for trying to figure this out. </TD></TR></TABLE>
This is true, and they're shocks not struts fyi.
Old Nov 7, 2005 | 07:32 PM
solsi2000's Avatar
Default Re: for all you ground control and kyb agx people.. (AutoXer)
i believe they are the regular lenths and rates that are for the 92-00 civic
thanks for your help. im still puzzled...
Old Nov 7, 2005 | 07:46 PM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>there are struts... not shocks
Old Nov 7, 2005 | 08:35 PM
AutoXer's Avatar
Default Re: for all you ground control and kyb agx people.. (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">there are struts... not shocks</TD></TR></TABLE>
The 88-00 civics came with a coilover shock (also dubbed multilink or double wishbone) suspension. The 2001+ civics have a McPhearson strut suspension up front.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsi2000 &raquo;</TD></TR><TR><TD CLASS="quote">i believe they are the regular lenths and rates that are for the 92-00 civic
thanks for your help. im still puzzled...</TD></TR></TABLE>
So what are the numbers on each of the springs on the corners?
Old Nov 7, 2005 | 09:13 PM
solsi2000's Avatar
ok now stfu about them being shocks and not struts. dont post if your going to say that. i will jack the car up tom and find out.
Old Nov 8, 2005 | 12:30 PM
solsi2000's Avatar
hey found out what the problem was. the front springs were mixed up with the rear.
Old Nov 18, 2005 | 03:36 AM
mdd's Avatar
mdd
i had that same problem. some stupid ht user wrote the wrong directions and i since i didnt have instructions (used) i believed him.. stupid on my part.... but still i thot ppl who write advice would at least know it to be correct when they do kinda annoying.
Old Nov 18, 2005 | 07:27 AM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsi2000 &raquo;</TD></TR><TR><TD CLASS="quote">ok now stfu about them being shocks and not struts. dont post if your going to say that. i will jack the car up tom and find out. </TD></TR></TABLE>
AutoXer was trying to help you out and you blow him off like that?
Old Nov 18, 2005 | 07:37 AM
AutoXer's Avatar
Default Re: for all you ground control and kyb agx people.. (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">
AutoXer was trying to help you out and you blow him off like that? </TD></TR></TABLE>
No worries; it's just the net, and some people spout off for whatever reason. He fixed his problem, so it's all good.
Old Nov 18, 2005 | 10:19 AM
solsi2000's Avatar
mehh it wasnt directed to autoxer. he was just trying to help. thanks for everyones help.
PA MATT
Suspension & Brakes
Apr 21, 2005 05:32 PM
PA MATT
Suspension & Brakes
10
Apr 19, 2005 12:15 PM
stilzx61
Jan 18, 2004 03:01 PM
