How to solve piston deck clearance of 2-3mm....help needed..
Old Nov 7, 2005 | 08:15 AM
cyrix12's Avatar
Default How to solve piston deck clearance of 2-3mm....help needed..
anyone can enlighten on the question???....help needed...adding thicker gasket???
Old Nov 7, 2005 | 03:55 PM
ericrx_88's Avatar
Default Re: How to solve piston deck clearance of 2-3mm....help needed.. (cyrix12)
yep you got it
Old Nov 9, 2005 | 06:22 AM
cyrix12's Avatar
Default Re: How to solve piston deck clearance of 2-3mm....help needed.. (ericrx_88)
Hi
is that the only way to solve this problem??
Old Nov 9, 2005 | 07:08 AM
rainforest's Avatar
no but it is the easiest way and most insxpensive.
Old Nov 9, 2005 | 08:29 AM
PURPLETERROR aka BIGMATT's Avatar
you have some serious problems if your piston is sticking out of the hole 2-3 mm
Old Nov 9, 2005 | 08:40 AM
CHEETAH's Avatar
what is the problem ? the piston is out the hole 3mm and you can;t clear the piston "flat" to the bottom of the head ? I usually leave 40-45 thous clearance ... if its out the hole and doesn;t clear the 40-45 thous clearance then the only alternative is to use a thicker gasket
Old Nov 11, 2005 | 06:27 AM
cyrix12's Avatar
Default Re: How to solve piston deck clearance of 2-3mm....help needed.. (CHEETAH)
Hi..thks for the advise...planning to get my hands on a 3mm thick gasket...anyone who can suggest a brand which has readily made 3mm thick gasket??..or must it be custom made???
Old Nov 11, 2005 | 06:44 AM
Mleach's Avatar
3mm - that's not a gasket; that's a spacer!
Old Nov 11, 2005 | 06:57 AM
743power's Avatar
Default Re: How to solve piston deck clearance of 2-3mm....help needed.. (Mleach)
bye bye quench
Old Nov 11, 2005 | 07:35 AM
no2psi's Avatar
Do you have any pictures? How did you end up with the pistons 3mm out the block?
G-power
Nov 6, 2016 10:17 AM
H-allmotorda9
Feb 5, 2010 02:42 PM
ge_itr
Jan 24, 2008 09:59 AM
Si Shane
May 22, 2005 08:54 PM
