GReddy guage install
Im installing some new greddy 52mm electronic guages and im wondering this question....i have all the wires hooked up except one....the white lighting wire...i looked at the wire diagram for the haynes manual but cant figure out which one it is.....what color/stripe is it and where the hell is it
tks much
tks much
go to the underdash fuse box, look for cluster light, take fuse wrap the wire on ONE end of the fuse, stick it back in... this way when you do decide to remove the gauge eventually you wouldn't have splices on factory wires. I always suggest this because 1. mentioned earlier; 2. gauges such as Defi, Autometer, HKS, Blitz, etc. they don't want you wiring a small *** bulb in their gauges inline with big bulbs such as headlights for power source. 3. If the gauges has a dimmer function, you can dim it as well when you dim the brightness of your cluster
