greddy gauge install..
Old Apr 23, 2002 | 02:27 PM
bruthaboost's Avatar
Default greddy gauge install..
Hey y'all,
I'm installing some greddy gauges and I'm wondering where did all y'all patch in the parking light source line? It's the white wire on the greddy wire harness.
Old Apr 23, 2002 | 10:33 PM
Flamenco-T's Avatar
Default Re: greddy gauge install.. (b18bpwr)
jeff, I tapped it in the instrument light fuse... the purpose is so that when your cluster is on, the gauge is on, when it;s off, it's off
stan
Old Apr 24, 2002 | 07:07 PM
Default Re: greddy gauge install.. (Flamenco-T)
Many thanks stan.
Old Apr 24, 2002 | 07:17 PM
ElectronVTEC's Avatar
You can also use the illumination lead going to your radio if you have a Helms wiring code handy. HTH, EV.
Old Apr 24, 2002 | 07:51 PM
adam's Avatar
Default Re: greddy gauge install.. (ElectronVTEC)
or GRN/RED coming from the headlight switch, that wire gets signal when you turn on the parking lights
Old Jun 27, 2017 | 09:59 AM
Krazy613's Avatar
ive always used the pins on the fuse box. Just have to fuse your wire coming off the fuse box pin.
Old Jun 27, 2017 | 10:50 AM
Schister66's Avatar
Man U FTW
You should check the dates before posting. This thread hasn't been active for over 15 years....If the OP hasn't figured it out by now, its not getting fixed
pubestripe
Sep 19, 2006 01:24 PM
milanored95eg
Nov 7, 2005 06:03 AM
zojirushi
Jun 23, 2002 06:01 PM
S13 slide
Jan 20, 2002 10:35 PM
