last mini me thread ever!!
Old Nov 6, 2005 | 09:47 PM
torqueless's Avatar
Default last mini me thread ever!!
from me that is...
I have a d15b7 and today my buddy told me he will sell me his y8 head for $80! wich seems extremely cheap, what all do i need to do a complete head swap? I know i need: y8 ecu,y8 dizzy, but thats all i know, what else is needed for complete swap? I PROMISE IVE SEARCHED! and i cant the info im seeking, i used to have a complete mini me swap guide on my favorites, but all my favorites got erased last week.
p.s. would the compression ration be the same on a mini me as a d16y8? also a mini me is still a 1.5L correct??
Old Nov 6, 2005 | 09:49 PM
sockvtec's Avatar
Default Re: last mini me thread ever!! (torqueless)
https://honda-tech.com/zerothread?id=735196
Old Nov 6, 2005 | 10:01 PM
torqueless's Avatar
Default Re: last mini me thread ever!! (sockvtec)
THANK YOU
Old Nov 6, 2005 | 10:05 PM
civic_driver's Avatar
https://honda-tech.com/zerothread?id=554053
Old Nov 7, 2005 | 06:06 PM
torqueless's Avatar
Default Re: (civic_driver)
ok i understand it all, the only thing i dont get is that they say when you put the vtec head on it raises the compression. what can i do to keep the compression down to 9.2:1 or lower since it will be boosted??
Old Nov 7, 2005 | 06:10 PM
kaiba's Avatar
Default Re: (torqueless)
head gasket maybe
Old Nov 9, 2005 | 07:07 PM
torqueless's Avatar
Default Re: (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueless &raquo;</TD></TR><TR><TD CLASS="quote">ok i understand it all, the only thing i dont get is that they say when you put the vtec head on it raises the compression. what can i do to keep the compression down to 9.2:1 or lower since it will be boosted??</TD></TR></TABLE>
bump!
Old Nov 9, 2005 | 07:31 PM
92ehatch's Avatar
lower compression pistons?
use a thicker head gasket as well
Old Nov 9, 2005 | 08:04 PM
torqueless's Avatar
Default Re: (93egsedan)
well how are peopleboosting mini me's w/ stock internals and such a high cr?
Old Nov 10, 2005 | 04:58 PM
torqueless's Avatar
BUMP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueless &raquo;</TD></TR><TR><TD CLASS="quote">well how are peopleboosting mini me's w/ stock internals and such a high cr?</TD></TR></TABLE>
also will a '99 y8 head fit a 93' d15b7 block?
Old Nov 10, 2005 | 05:26 PM
hplssone's Avatar
yes the y8 will work with a d15, but the compression will be around 10.25:1
Old Nov 10, 2005 | 05:28 PM
hplssone's Avatar
Default Re: (hplssone)
use a fuel management system, a lower temp thermostat, lower temp spark plugs, higher octane fuel, larger injectors, retard the timing for higher compression with boost
Old Nov 10, 2005 | 11:25 PM
torqueless's Avatar
tomorrow im going to the honda dealership to buy a head gasket and timing belt for my mini me swap, i just want to make sure i'm buying the right parts. I have a '93 d15b7 bottom end, and a '99 d16y8 head. So i need the y8 timing belt, and y8 head gasket correct? I just want to be 100% clear on this!
Also with the compression being 10.2:1 w/the mini me swap, whats the maximum boost psi i can push while still being safe with a small 16g and proper tune w/ neptune ems?
My friend had this same turbo on his d16y8 (9.6:1 cr) and he ran on 10psi all season with no problems, then one time he boosted it to 12psi and blew the head gasket. so would 9.6:1cr w/10 psi be equivlant to about 8psi w/ 10.2:1cr?? and how much more boost can it handle if i got some arp head studs?
Old Nov 11, 2005 | 10:04 AM
torqueless's Avatar
BUMP!
also i need someone with experience with a mini me swap who used a b7 bottem end y8 head. Im running into some problems. first problem is the y8 head i bought has ports the the outer side of the block(dizzy side) and the b7 block does not. wont there be blow by? also the y8 dizzy only has one plug, where the b7 dizzy had 2. Someone PLEASE help me Out!
Old Nov 11, 2005 | 10:25 AM
swifty4u's Avatar
I'm guessin your car is a 92-95 if you have a b7 correct? If so, your car is obd-1 and your car wont work directly with that dizzy. I'm pretty sure you can just put in a z6 dizzy, maybe even the stock dizzy will work?
Old Nov 11, 2005 | 01:12 PM
torqueless's Avatar
Default Re: (swifty4u)
ok new big problem!! HOW THE HELL DO I GET THE CRANK PULLIE TO BREAK LOOOOOSE!!!!!!!??? i tried my impact gun, didnt work, i just bought an electric impact gun, didnt work. any tips?
Old Nov 12, 2005 | 05:33 AM
hplssone's Avatar
I usually have to put the 1/2 inch air gun to those to get them off
Old Nov 13, 2005 | 03:51 PM
torqueless's Avatar
ok new problem, i put the y8 head on and used the y8 timing belt, i matched up the timing marks on the cam gear and crank gear, and then turned the crank over 1 full time, and checked the timing marks again, but the crank cam is a bit off to the right, so i moved the belt back a tooth, and now its a bit off to the left. The belt has 104teeth, and the b7 belt had 106 but had to much slack, its like there needs to be a belt with 105. any suggestions? p.s im using the b7 block w/y8 head
Old Nov 13, 2005 | 07:49 PM
torqueless's Avatar
BUMP!
Old Nov 14, 2005 | 12:18 PM
torqueless's Avatar
someone help me!!!!
Old Nov 14, 2005 | 12:39 PM
teal_dx's Avatar
I did the y8 mini me on my d15b7 block. use your D15b7 dizzy, it will work fine. you will need the y8 plug wires though, the 1.5 do not fit right. the y8 HG is slightly thinner than the z6 HG. if you want less compression, get the Z6 HG.
M_conner96
Jan 13, 2013 12:14 PM
TYPEcRx
Aug 14, 2011 04:59 PM
zoopreme
Nov 17, 2009 10:40 PM
SPOON_BeIgHtEeNsEe
Northwest (Sales)
Jul 20, 2008 02:47 PM
d1nki
Jun 22, 2006 01:11 PM
