b18c into ek throttle cable 2 short?
im almost done with my swap...a 97 jdm b18c-R into my 96 civic dx.
for all those that swapped a b-series into an 96-00 ek, did u use ur stock throttle cable?
my car is a 96 DX and my throttle cable seems to be too short...i tried adjusting it but it still seems to b to short.
i connected it to the throttle but since its too short it keeps the throttle body open about a 1/4 at all times.
therefor the car will constantly be at 1/4 throttle because the cable isnt long enough for the throttle to go back to normal rest position.
anyone else have this problem? do i have to swap the DX throttle cable for a 99-00 civic si cable, since they came with a b-series from the factory?
any input would be great as i am going to finish up tom hopefully
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K SERIES »</TD></TR><TR><TD CLASS="quote">you need a type r throttle cable and bracket.</TD></TR></TABLE>
can anyone confirm this?
a 99-00 si throttle cable wont work as well?
You can either get a throttle cable from a hype-r, OR you can do it like it was done on my car....
Ugly as hell but it works until you get that Hype-R bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt »</TD></TR><TR><TD CLASS="quote">You can either get a throttle cable from a hype-r, OR you can do it like it was done on my car....
Ugly as hell but it works until you get that Hype-R bracket</TD></TR></TABLE>
looks like ill try that untill i get a new throttle cable....BUT WILL A 99-00 si cable work? i already have the type r throttle cable bracket...it came attached on the manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. JDM-GSR »</TD></TR><TR><TD CLASS="quote">FuNkDrSpOt is your car 97 civic</TD></TR></TABLE>
Yes, it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akteamster »</TD></TR><TR><TD CLASS="quote">
looks like ill try that untill i get a new throttle cable....BUT WILL A 99-00 si cable work? i already have the type r throttle cable bracket...it came attached on the manifold.</TD></TR></TABLE>
No idea, but the Hype-R cables are about $25. I just ordered one. I got tired of looking at that ugly *** mess
Yes, it is.
gapergurlie_18
Oct 23, 2008 05:22 PM
akteamster
Nov 10, 2005 08:35 PM
