accord 90 ex-r heat problem
Old Nov 6, 2005 | 07:21 PM
Role Model's Avatar
Default accord 90 ex-r heat problem
alright winter is almost here and my heater is blowing like 25% or less of hot air out and take like a hour to defrost the car from a to z so does anyone have a idea what to do?! Its a 1990 Honda Accord EX-R 2doors
Old Nov 6, 2005 | 09:12 PM
deserthonda's Avatar
Default Re: accord 90 ex-r heat problem (SpoonModel)
does it blow enough air just not hot??? or not enough air at all ??? if it blows planty but not hot , chk the t-stat, heater valve adjustment and oparation of the heater doors..........If not enough air flow u could have a partially plugged evap
Old Nov 8, 2005 | 09:43 AM
Role Model's Avatar
Default Re: accord 90 ex-r heat problem (deserthonda)
not enough air at all :S
Old Nov 10, 2005 | 08:10 PM
Role Model's Avatar
bump
Old Nov 10, 2005 | 08:37 PM
JTB's Avatar
JTB
is your blower fan working on all the speeds?
Old Nov 10, 2005 | 09:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonModel &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
did u read what i said if it did not blow enough air???,,
Old Nov 11, 2005 | 12:18 PM
Role Model's Avatar
its working on all speed but when i change from heat to face of feet to defrost nothing change
Old Nov 11, 2005 | 03:17 PM
is there planty of air coming from the vents when it is in other settings other than defrost........??? is defrost the only lack of air flow?? if so you need to chk the door adjustments
Old Nov 15, 2005 | 02:54 PM
Role Model's Avatar
not i mean it lack of power on each switch you try
Atalbot20
Mar 31, 2018 09:32 AM
debbieyakiwchuk
Jul 27, 2017 04:27 PM
tjjm36m3
Dec 9, 2008 09:07 AM
quizbo99
May 29, 2008 09:21 PM
khmerxnuttyxb
Oct 14, 2007 10:24 AM
