94 Accord,Many Problems
Old Nov 6, 2005 | 06:12 PM
e59291's Avatar
Default 94 Accord,Many Problems
My accord started acting up. I lost my power windows, tach, speedometer, fuel, temp gauge, rear defroster
and tranny has to be manually diengaged from park with key. Been breaking my head. Fuses under dash fine,
fuses under hood good except for all window fuses. Tried resetting tcu with fuse #39 but no luck.
Took battery off for an hour, no luck. Car drives and shifts fine, but above not working. Please Help!
Old Nov 6, 2005 | 09:25 PM
deserthonda's Avatar
Default Re: 94 Accord,Many Problems (e59291)
holy cow ........well lets take it 1 step at a time.........u said windows fuses are bad?? replace fuses and see if windows work although it is pretty weird that all 4 fuses would be bad..........chk to see if brake lites work, if not see if horn works if it does, jump the brake switch and see if u can car out of park by just depressing the brake pedal,,,,,,,,if horn is inop. chk the fuse ..,,, is the chk engine lite on ?? ..it also sound like u could have an issue with the instrument cluster for all of those gauges to go at same time ,,,perhaps a bad ground ??
Old Nov 11, 2005 | 04:52 AM
e59291's Avatar
Default Re: 94 Accord,Many Problems (deserthonda)
Horn works and so do brakes. Noticed my back up lights don't though. Going to change the fuses
and check ground connections today. Thanks.
Old Nov 11, 2005 | 05:17 AM
most likely u got a bad brake switch,for the cannot get out of park.....,,,,,if fuse for back up is ok, chk the connection at the tranny , if connection is ok, jump those 2 wirs together see if reverse lites come on,, if so,, u got a bad switch
JPelto
Jul 26, 2014 06:13 PM
djsimm89
19
Feb 24, 2009 11:17 AM
HybriDNA
Dec 7, 2003 07:14 PM
mechanik
Jun 14, 2002 05:41 PM
mechanik
Jun 14, 2002 05:38 PM
