ITR cluster in a EG6 hatch?!
Old Nov 6, 2005 | 04:54 PM
VTECth1s's Avatar
Default ITR cluster in a EG6 hatch?!
im currently using the SI-R cluster...i want to use the ITR cluster..is it a plug and play cluster? or what do i do? cuz i do have a LS/VTEC motor so i assume it uses the integra cluster. Thanks.
Old Nov 6, 2005 | 04:56 PM
duggy's Avatar
You can still use the stock cluster. If you want a tach, then go with the ex/si cluster.
Old Nov 6, 2005 | 04:58 PM
Soccerking3000's Avatar
Default Re: (duggy)
yea the cluster will wokr fine with your setup, as for the itr cluster it is not plug and play you need to actually do some fab work to get it to fit and not look like crap
Old Nov 6, 2005 | 05:29 PM
VTECth1s's Avatar
Default Re: (Soccerking3000)
i see..would i be able to use the same dashboard as well?
Old Nov 6, 2005 | 05:30 PM
Default Re: (V8-eater)
yes but you need to cut part of the dash out so it fits well, do a search there is a write-up on how to do it
Old Nov 6, 2005 | 05:42 PM
VTECth1s's Avatar
all i needed to know..did you do this on ur car as well?...thanks
Old Nov 6, 2005 | 05:49 PM
resol's Avatar
i just did an 2000 gsr cluster in my hb, you need to the plugs for the cluster to do this
Old Nov 6, 2005 | 06:51 PM
riceburnerryan's Avatar
and the gauge bezel needs to be cut about 2.5 inches? and re wiring ...
Hectorzg1
Feb 22, 2010 06:44 PM
DaFredsta
Oct 18, 2009 01:31 AM
jfoster
Nov 13, 2005 04:46 AM
allnapower
Feb 24, 2005 02:03 PM
:jdmshmaydm:
Apr 29, 2003 04:13 AM
