I got tranny problems! Grinding in reverse!
Old Nov 6, 2005 | 03:52 PM
SuperSi's Avatar
Default I got tranny problems! Grinding in reverse!
I did a couple of WOT runs in my car earlier and I heard a grind in first on my first WOT run. I started worrying and after about 10 WOT runs I was sure that I might have let off the clutch early or I did not get the shift in right. So when I get home I need to back up to get in my garage and my whole car shakes and it grinds in reverse. But here's the thing it only grinds when I put the clutch in and go straight to reverse but If I move the shifter to first and engage into reverse it does a bad grind. It sounds weird but Im tripping out. I also installed my axles like a week ago and did not change the tranny fluid. I have a b16a2 w/stock tranny btw if that helps.
Old Nov 6, 2005 | 04:02 PM
komat's Avatar
Default Re: I got tranny problems! Grinding in reverse! (SuperSi)
when you put it in reverse is the car in a complete stop?
Old Nov 6, 2005 | 04:15 PM
black_EM1's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSi &raquo;</TD></TR><TR><TD CLASS="quote">If I move the shifter to first and engage into reverse it does a bad grind. </TD></TR></TABLE>
Bad idea,man. Maybe alittle too much tranny fluid leaked out when you chnged the axles. Try using some GM Synchromesh. Also Si trannies are weak to begin with
Old Nov 6, 2005 | 05:23 PM
intake's Avatar
B A N N E D
Default Re: I got tranny problems! Grinding in reverse! (black_dohc)
I remember in my GSR my reverse started going out, i didnt mind it.. But then i slammed it into reverse really hard one time and my gears went out.. 1st/2nd and 5th..
i was driving in 4th gear on the freeway from North county to san ysidro.. ******* sucked.. then i had to pay like $ 1k for another 99 gsr tranny with installation and clutch and Blah..
get it fixed or bang the expletive out of the tranny and get another one!
polishedturd
Nov 29, 2007 05:59 AM
Historyg
Oct 6, 2007 03:14 PM
ajrees25
10
Oct 10, 2005 04:31 PM
Manolo
18
May 18, 2005 09:21 AM
bones_accord
Feb 16, 2003 08:12 PM
