Using an OBDI distributor
Well, i nblew up my 2nd mtor b/c of too much boost and one injector was bad. I bought another motor, F22B2 thnking that it was OBDII but it isnt. So now i gotta figure out how to wire it up so that it will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accrdpusha »</TD></TR><TR><TD CLASS="quote">F22B2 thnking that it was OBDII but it isnt. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accrdpusha »</TD></TR><TR><TD CLASS="quote">I got an F22B2 with an OBI distributor and I am OBII.</TD></TR></TABLE>
huh??? Just go purchase the correct dist.
the motor is OBDI. I am OBDII. Same motors, one doesnt have the sensors in the distributro, OBDII. Im trying to figure out how i can wire it up to work.
This Technical Thread should have what you're looking for
Hope it helps
http://accordinglydone.com/for...=9474
P
Hope it helps
P
that thread link above should help you, but i must ask, you had a motor in there before you blew it up im assuming, so why not retain your orginal obdII distributer? did you throw it away with the motor?
No. The motor i bought is OBDI, I didnt know that. On OBDII there are two sensors down behind the crank, on OBDI those sensors are in the distributor. I am an active meber on that site but when i did the wiring, my car still didnt crank up.
vxnine
Jul 25, 2005 03:20 PM
BLUE EH3
21
Jan 10, 2004 11:22 PM
