cx with no a/c dash, work in a 96 si dasH!! ?!? JDM
Old Nov 6, 2005 | 01:42 PM
G2 Speed's Avatar
Default Can I use a Climate Control dash from a 2000 CX with....
Can I use a Climate Control dash from a 2000 CX, with no A/C, but it includes everything harness,heaterbox, blowerbox, in my 1996 Si? and have a/c?
Modified by G2 Speed at 5:53 PM 11/6/2005
Old Nov 6, 2005 | 02:03 PM
G2 Speed's Avatar
Default Re: Can I use a Climate Control dash from a 2000 CX with.... (G2 Speed)
bump cause I need to know before 2night
Old Nov 6, 2005 | 02:06 PM
b18ctrb's Avatar
Yes you can use the climate control. You dont need the AC
Old Nov 6, 2005 | 02:34 PM
G2 Speed's Avatar
Default Re: (b18ctrb)
I want to keep the a/c my 96 has ac already, i'm wondering if i can use the cx climate control with no a/c with my current set up and have a/c?
Old Nov 6, 2005 | 02:49 PM
b18ctrb's Avatar
I dont think you would be able to. There will be no button to turn the ac on then
Old Nov 6, 2005 | 02:52 PM
G2 Speed's Avatar
i can buy the button for 10 dollars of honda automotive parts, right now there is a block off button?
Old Nov 6, 2005 | 03:25 PM
b18ctrb's Avatar
SO you are doing the 99-2000 conversion then right? If your car has the AC but the unit itself does not? If every thing is there for the swap it might work.
Old Nov 6, 2005 | 03:33 PM
G2 Speed's Avatar
like there is a converison on honda-tech for the full 96-98 - 2000 swap
I'm getting all of that stuff except, it says nothing about the a/c portion... currently there is a block off button, were the a/c should be..
Old Nov 6, 2005 | 04:00 PM
G2 Speed's Avatar
Default Re: (G2 Speed)
anyone?
Old Nov 6, 2005 | 04:28 PM
G2 Speed's Avatar
I need to know I'm getting all the climate pieces blower motor, harness etc.. for 150 canadian...
Old Nov 6, 2005 | 04:49 PM
b18ctrb's Avatar
I think it should work. **** for that price pick it up any way. Thats a hella deal
Old Nov 6, 2005 | 04:56 PM
G2 Speed's Avatar
the blower box and resistor are like that much I think it should work I just need that button
dylaxiin
Apr 7, 2011 03:05 PM
97civic123
Nov 13, 2006 12:30 PM
7808
Dec 21, 2005 10:29 PM
impr323
May 1, 2005 01:44 AM
2000_Civic_Si
15
Aug 22, 2002 08:28 AM
