Over-rev my motor….. Bent Valves?
Old Nov 6, 2005 | 11:06 AM
spoonhatchblack's Avatar
Default Over-rev my motor….. Bent Valves?
Hey Guys I recently over-rev my motor & the #4 piston went out!
Now that I got the block Fixed. I assembled the motor Using the same B18C1 Head.
Re-Did the Valve Adjustments Perfectly. OE Specs.
Problem:
Now the car Sounds Like a Truck Motor?? (From the Head)
It doesn’t sound Like a stock Normal (Quiet) Head (like before the over-rev)
It seems like the #3 Intake or Exhaust Valves are not closing completely or functioning Normal because that’s where the Noise is coming from!
Because when I try to rev the motor past 4K it boggs. But when you Partial Throttle You’ll Kinda get by.
What does this problem seem to Be Guys???
Old Nov 6, 2005 | 11:27 AM
NA.GEORGE's Avatar
Default Re: Over-rev my motor….. Bent Valves? (spoonhatchblack)
it shoulds like bents valves
do a compression check and see what u compression in each cylinder is
and take the head off and get it checked out
good luck
Old Nov 6, 2005 | 11:28 AM
sohcnotec's Avatar
I recently bought an over revved C1 for cheap.
Took the head off and found that the #3 cyl exhaust valve was leaking too.
Haven't fixed it yet.
The valve doesn't seat properly. I have yet to remove the valves to check if they are bent.
BTW I just poured some water into the exhaust port to find the leak. May not be the best check but, it worked for me. I'll have it properly checked later on some time.
Old Nov 6, 2005 | 11:46 AM
Default Re: Over-rev my motor….. Bent Valves? (sohcnotec)
did a compression seems to be okay 155-160psi all 4.
can there be other symptoms for checking valves?
Old Nov 6, 2005 | 01:26 PM
Echo7847's Avatar
Leakdown test will help pinpoint any problems
Old Nov 6, 2005 | 01:27 PM
NA.GEORGE's Avatar
is there a hishing sound coming from the head if u manually turn over the motor
thats what i heard when i had bent valves and then i took off the head and i could see the 3 bents valves i had
Old Nov 6, 2005 | 09:33 PM
Default Re: Over-rev my motor….. Bent Valves? (NA.GEORGE)
Since you mentioned the hissing noise..
I hear that just earlier when i shut the car off.
normally theres nothing there.
Old Nov 6, 2005 | 09:38 PM
rjay8604's Avatar
That just the hissing of vacuum hissing when you shut it off. Honestly sometimes it sounds funny when it works correctly. B-series motor have a very loud and mechanical sounding valvetrain, there's a whole lot of action under the valve cover, 6 rockers per cylinder. Header will make it sound louder as well, more valvetrain noise.
89si-rex
Jan 5, 2014 05:54 PM
HondaKid_1
Jul 30, 2008 05:26 AM
spoonhatchblack
Nov 6, 2005 11:10 AM
spoonhatchblack
Nov 6, 2005 11:09 AM
R-Toyz.com
Oct 21, 2004 09:36 AM
