Balancer shaft oil seal !!!!!!!!!!
Old Nov 6, 2005 | 09:44 AM
gamblezhang
Guest
Posts: n/a
Default Balancer shaft oil seal !!!!!!!!!!
i need to replace the balancer shaft oil seal !!!! does anyone know how many hour to do that? one person.
Old Nov 6, 2005 | 09:49 AM
revlimitx04's Avatar
Default Re: Balancer shaft oil seal !!!!!!!!!! (gamblezhang)
Depends on your skill, could accomplish it in a days worth of work.
Old Nov 6, 2005 | 10:16 AM
gamblezhang
Guest
Posts: n/a
that guy use to work for toyota...so i want to know in normal speed take how many hours? bz i need the car tomorrow.
Old Nov 7, 2005 | 02:57 PM
LOrangeH22hatch's Avatar
I can do it in about 2 hours, but that is in our shop with air tools and a lift, and alot of experience. So alot depends on tools and so forth. You should be able to do it in a day.
Old Dec 5, 2008 | 02:28 PM
92b16si's Avatar
anyone have a how to link?
Old Dec 5, 2008 | 02:35 PM
vinuneuro's Avatar
Dl the service manual http://www.spoonhonda.com/Free_Downl...uals_s/119.htm . Your guy should be able to get an idea from looking at. Replacing the balancer shaft seal is pretty much the same as a timing belt job, labor wise.
Old Dec 5, 2008 | 06:36 PM
TruNinja619's Avatar
Tip: if you coat the outter diameter of the oil seal with honda-bond, it makes it easier to install.
Old Dec 5, 2008 | 06:50 PM
m00nr0ck Si's Avatar
man I did the balance shaft seal and the seal retainer ,cam seals, new timing belt in prolly 4-5 hours.....its really not that hard,just dont get in a hurry , do it right and make sure to install the retainer so it doesnt back out......
rulvis
Dec 21, 2008 06:29 PM
omeara7
Jul 10, 2004 09:34 AM
Chiovnidca
Jan 3, 2003 10:28 AM
