is this a z6 or y8 head
Old Nov 6, 2005 | 09:21 AM
gnar kill's Avatar
Default is this a z6 or y8 head
okay this kid sold me a z6 block and said it had a y8 head. He swears it is a y8 head. Not that it matters to me because either one will work for what I am doing. I just want to make sure I get the thing all aligned right because it has the y8 cam gear on it and I think the y8 cam gear is 4 degrees advanced as opposed to the z6
my z6 valve cover fits the head, and a td42u z6 dizzy fits the head so I am almost sure it is a z6. My z6 head I have on my car now has po8-3 stamped on it and this one has po8-5. My main concern is I have an adjustable cam gear and I need to know who to set it and I want to get a zex cam and I need to know which one to get. sorry so long thanx
CAsey
Old Nov 6, 2005 | 04:23 PM
gnar kill's Avatar
Default Re: is this a z6 or y8 head (gnar kill)
bump for help
Old Nov 6, 2005 | 04:25 PM
CoreyR's Avatar
just look at the date stamped on the head if it was made in 92-95 it has to be a z6. 96-00 its a y8
Old Nov 6, 2005 | 04:32 PM
ryan89crx's Avatar
what does the head stamp say? it should be right about the #2 and #3 exhaust ports. z6 should be P08-? and y8 should be P2J-?
Old Nov 6, 2005 | 04:41 PM
ungcobob's Avatar
i have the same problem too. i bought crx z6 block, but im not sure if the head is a z6. ONly because i was checking out the valve cover and i pulled on a bolt and it came out easily. is that a bad thing? All the bolts do the same
Old Nov 6, 2005 | 05:19 PM
Slow ass EF's Avatar
Default Re: is this a z6 or y8 head (ungcobob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ungcobob &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem too. i bought crx z6 block, but im not sure if the head is a z6. ONly because i was checking out the valve cover and i pulled on a bolt and it came out easily. is that a bad thing? All the bolts do the same</TD></TR></TABLE>
??? your post is confusing. crx z6 block? valve cover bolt?
Old Nov 6, 2005 | 05:35 PM
CoreyR's Avatar
Default Re: is this a z6 or y8 head (slow *** ef)
po8-5 is a D16Z6 head. should be from a 94.
Old Nov 6, 2005 | 05:36 PM
EJ2-Fluffy's Avatar
Look on the head. There is an identification with a circle split in two with a number in each. If its 92-95 its a Z6, if its 96+ its a Y8. You can almost tell by the chambers of the Head if u took it apart.
Old Nov 6, 2005 | 06:00 PM
mike93eh
Guest
Posts: n/a
look at the year on it. its in front above the exhaust manifold. or you can tell by looking at the bottom of the head. z6 has round combustion chamber and y8's are more squared off. you can also tell by looking at the lost motion assemblies.
Old Nov 6, 2005 | 06:14 PM
rex chick's Avatar
Default Re: (mike93eh)
if ur z6 dizzy fits then is a z6 head
cause they both have diferents dizzys
Old Nov 6, 2005 | 06:27 PM
ryan89crx's Avatar
just look at the damn head stamp...quick and easy
Old Nov 6, 2005 | 09:43 PM
gnar kill's Avatar
Default Re: (ryan89crx)
thanx guys...I thought that 9/4 circle thing was just some sort of casting number but now I know I got a z6 head...thanx
Casey
z6dxej1
Apr 24, 2012 10:19 PM
The93egg
Oct 28, 2008 08:27 PM
The Internet Tough Guy
Apr 17, 2006 12:01 PM
SOHC_MShue
Jun 1, 2003 12:30 PM
