HELP! need to convert my obd1 motor to obd2 for obd2 car
Old Nov 6, 2005 | 08:48 AM
SHG_EasyE's Avatar
Default HELP! need to convert my obd1 motor to obd2 for obd2 car
i have a 94 intagra which is totaled, but the front clip is untouched, therefore i have a complete swap. i will be swapping into a 96-98 civic dx hatch. ive never done a swap before but really want to do it myself and lean so i need to know what kind of wiring, ecu, motor mounts and ANYTHING else i will need for the conversion. btw i will be using a skunk 2 manifold. thanks for any help!
Old Nov 6, 2005 | 09:24 AM
NXLude's Avatar
its easier to convert the car to obd1
Old Nov 6, 2005 | 11:17 AM
SHG_EasyE's Avatar
Default Re: (NXLude)
yea but its illegal and there will be no obd2 plug when it needs to be inspected. i dont have someone who will illegally inspect an obd2 car- the machine needs to get a reading off the car to print out the sticker.
Old Nov 6, 2005 | 11:23 AM
SHG_EasyE's Avatar
Default Re: (spoonjdmdc2)
can i just get an obd2 gsr ecu and harness, injectors, distributor or whatever else that is differnt on the engine? in essence just make the motor into that of one out of say a 98 gsr? or does the gsr harness not work in the civic? inthat case would a civic si ecu harness work?
Old Nov 14, 2005 | 05:52 PM
phateless's Avatar
there's a lot of **** to do to make a car obd2. do a search you'll turn up good info. to use that motor you're better off buying a 95 or older car...
Old Nov 15, 2005 | 07:06 PM
lsvtecracer's Avatar
Default Re: (phateless)
I would just use the stock harness and add the wires for the vtec, etc. Our shop convert obd1 motor to obd2 all the time and it's really not that difficult. You need a 99 si rear mount bracket, obd2 distributor, obd2 injectors, and ecu. If you use the ex harness then you don't have to convert the idle speed control to 2 wires. if you use the dx harness then you need to search on how to convert to a 2 wires. We usually get an obd2 to obd1 harness and use an obd1 ecu, but if you must use an obd2 ecu then you need to change the oil pump to obd2 so you can mount the cfk sensor. Beside that, it's mostly plug and play. Just pm me if you have any questions.
emooheo
Mar 13, 2010 12:37 PM
1.8L_allmotormilitia
May 2, 2007 08:28 PM
Civic98KH
Mar 11, 2007 09:21 PM
akoreanyoungsta
Jul 8, 2006 06:22 PM
DGAF
Jul 1, 2005 08:16 PM
