Would 84.5mm pistons fit in a 84mm bore?
Old Nov 6, 2005 | 07:18 AM
SpoonEk253's Avatar
Default Would 84.5mm pistons fit in a 84mm bore?
I wanted to know if 84.5mm pistons would fit into a 84mm bore? if not, what would i have to do to get them to fit?
Old Nov 6, 2005 | 08:48 AM
NJIN BUILDR's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (SpoonEk253)
You will need to have the block honed to fit the pistons.I'm not sure why you would even ask such a question.
Glenn
Old Nov 6, 2005 | 05:07 PM
Slow ass EF's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">You will need to have the block honed to fit the pistons.I'm not sure why you would even ask such a question.
please think before you ask such a question. its almost like asking will my car go through my front door.
Old Nov 6, 2005 | 06:40 PM
HamiltonRex's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (slow *** ef)
Just heat up the block.. Use a sludge..
Dude its like trying to fit a square peg in a round hole.
Old Nov 7, 2005 | 06:47 AM
dinko's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonEk253 &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to know if 84.5mm pistons would fit into a 84mm bore? if not, what would i have to do to get them to fit? </TD></TR></TABLE>
hhahahahaha that made my ****** morning. time to get some coffee now. wow this tech/misc forum is impressive
Old Nov 7, 2005 | 07:10 AM
mmuller's Avatar
Mad Scientist
Default Re: Would 84.5mm pistons fit in a 84mm bore? (niann)
hey. i dont mean to steal your thread; but is there any way to put my 84mm pistons into my 81 mm block? if i try really really hard? i got some lube..? finesse that mother in there?
Im pretty good at putting big things in little places anyways.. whhart do you guys tihnk?
Old Nov 7, 2005 | 08:37 AM
shamoo's Avatar
Will you make something up for me please?
Glenn</TD></TR></TABLE>
Honed is not the correct term. He will need to have the sleeves BORED 20 over to fit an 84.5mm over an 84mm piston. A honing will not go to 0.020 inches.
You guys are mean. It's a simple question requiring a simple answer. A little silly, but we're all here to learn.
Modified by shamoo at 7:19 PM 11/7/2005
Old Nov 7, 2005 | 11:12 AM
vtecn8ive's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (shamoo)
man thats a crazy question. seems like a good signature.
Old Nov 7, 2005 | 04:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by shamoo at 7:19 PM 11/7/2005</TD></TR></TABLE>
Actually I do mean hone.My Sunnen CV616 will easily hone .020".I rarely bore a block if I'm not sleeving or need to correct an alignment issue.
Glenn
Old Nov 7, 2005 | 07:26 PM
rainforest's Avatar
bam!!! your right but not everyone thinks of a sunnen machine they think of a sunnen hone or a bottle brush style.
Old Nov 7, 2005 | 08:51 PM
xyrth's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (rainforest)
hey! i have that same machine!
so you don't change the stones for bore/hone finish?
Old Nov 8, 2005 | 06:54 AM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote"> Actually I do mean hone.My Sunnen CV616 will easily hone .020".I rarely bore a block if I'm not sleeving or need to correct an alignment issue.
Ahh, good to know. Wasn't aware that could be done.
Old Nov 8, 2005 | 09:20 AM
aj99si's Avatar
a lot of shops use a honing machine to bore blocks they use different stones. It is a lot cheaper to buy one honing machine to do both than buying a boring bar and honing machine.
Old Nov 8, 2005 | 09:48 AM
electric_rex's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (aj99si)
or sayin that my **** would fit in the same size condom you use.
Old Nov 9, 2005 | 04:32 PM
jdmsiR20's Avatar
Default Re: Would 84.5mm pistons fit in a 84mm bore? (electric_rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electric_rex &raquo;</TD></TR><TR><TD CLASS="quote">or sayin that my **** would fit in the same size condom you use. </TD></TR></TABLE>
hahah
Old Nov 9, 2005 | 08:01 PM
LSVTEC 91 Civic's Avatar
Banned
wow.. what a thread.
Chief Wenceslaw
Apr 14, 2006 07:07 PM
SloazzEKhatch
Dec 12, 2005 08:02 PM
SpoonEk253
10
Nov 8, 2005 09:58 AM
civic_d16y7
Apr 2, 2005 05:08 PM
TypeR0149
Aug 31, 2001 12:53 PM
