B18c type R engine swap
Old Nov 6, 2005 | 03:40 AM
Smooth Groove's Avatar
Default B18c type R engine swap
Hi, i´m considering swaping into my EDM Crx (EE8 w/ b16a) a B18C type R from an Integra. Sounds pretty fast, neede some info dough. Is this a direct bolt-in??? I´m getting new engine mounts at Injen Racing, i think all i need is Engine Block and ECU. Opinions and comments needed.
Keep on driving
Old Nov 6, 2005 | 05:01 AM
StorminMatt's Avatar
Default Re: B18c type R engine swap (Smooth Groove)
Well, if your car is already set up for a B16A (whether with a mount kit in USDM cars or from the factory in other countries), swapping over a B18C5 is no big deal, at least as far as mounting is concerned. You are correct in that all you need is the complete motor and ECU. The ITR motor will mount right up to your stock B16A transmission. There are, of course, two ways to go with the ECU. You can try to rechip your stock ECU to run the C5. Or you can rewire to use the P73. Each has its advantages and disadvantages. But I prefer the P73 since it is cheaper to use (if, of course, you can do your own wiring). Also, fuel economy is better, you can use the newer (more reliable) distributer, and you don't need that retarded twin oxygen sensor setup. But wiring can be a daunting task for those unaccustomed to it. And paying someone else to do the job can get expensive.
Old Nov 6, 2005 | 08:43 AM
Default Re: B18c type R engine swap (StorminMatt)
aren´t there harnesses available for this swap?
Old Nov 6, 2005 | 09:02 AM
Slomo_civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smooth Groove &raquo;</TD></TR><TR><TD CLASS="quote">aren´t there harnesses available for this swap?</TD></TR></TABLE>
Im sure rywire.com has something, and if not they can definately whip something up.
Old Nov 8, 2005 | 07:53 AM
Does anybody know a fellow Rex´er with such a swap? What can go wrong?
Should I go for the stock b18c type r or should i seriously consider the b18c that Spoon manufactures? This is your chance, fellow honda fans, to post a reply for a project that will make yall drool... Bigtime!!!!!!!
Old Nov 8, 2005 | 08:08 AM
drdisco69's Avatar
I have a cRx, it doesn't suck. I run the OBD0 PR3 with lots of tuning, but there are many options to run it. Since the motor comes with an OBD2 distributor and injectors and crap, just getting an OBD0-OBD1 conversion harness will allow you to use a P30, P28, or whatever else you want to work. There are pretty good tunes floating around for those motors, but the best way is to tune it yourself.
Old Nov 8, 2005 | 08:50 AM
hafftrak's Avatar
Ryan from Rywire has a parts list and how-to here:
http://www.norcalcrx.org/droppedcrxsi/
Old Nov 8, 2005 | 08:57 AM
c.dub's Avatar
Default Re: (hafftrak)
There's a guy on Super Honda dot com who goes by Jadkar, he's doing a B18C-R swap in his Rex right now. I'm sure you can get great responses here, but I figured I would let you know. The more info, the merrier.
Old Nov 8, 2005 | 04:31 PM
I've done a B18C5 swap on my CRX. The motor is a 1997 JDM ITR. Amd the ECU I am using is the JDM P73. And I did the wiring myself. Although this ECU uses OBDII-style plugs, wiring it up is very similar to wiring a 1992-1995 ECU. Like an OBDI ECU, there is just a single oxygen sensor, no crankshaft speed fluctuation sensor, and no fuel tank pressure sensor. Also, there is neither an evaporative purge valve nor a VTEC pressure switch. So it is actually simpler in a way than conventional OBDI.
Old Nov 10, 2005 | 08:39 AM
so whats the feeling you get out of the car? can you get the power to the tarmac? what significant changes did you get?
ArrizownEM1
Nov 7, 2012 11:12 AM
cslegacy
Jan 29, 2007 07:02 PM
civicCXI
Sep 22, 2006 12:32 PM
freakie
Oct 17, 2003 10:13 PM
-CP-
Sep 30, 2002 09:02 AM
