is ticking valves OK to drive?
It won't actually bend the valve itself. It will cause premature wear to the cams and rocker arms instead. How long it takes to start damage all depends on how out-of-spec the valve lash is.
Sometimes ticking valves can be mistakenly diagnosed.. Your injectors also make a pretty loud ticking noise. I thought it was my valves, turned out to be my injectors which is completely normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Sometimes ticking valves can be mistakenly diagnosed.. Your injectors also make a pretty loud ticking noise. I thought it was my valves, turned out to be my injectors which is completely normal.</TD></TR></TABLE>
yeah i thought it was my valves ticking too, but it was injectors.. until i misshifted 3rd gear and went to 2nd gear, then i learned what valves ticking sounded like.. ahha but got valve adjustment right away and found out my valves really needed adjustment.
EyePhoto
13
Apr 16, 2013 03:38 PM
