Suspension & Brakes Theory, alignment, spring rates....
f2 coilovers
Old Nov 5, 2005 | 09:16 PM
jaydmcrx's Avatar
Default f2 coilovers
-24-way dampening adjustable.
-0 to 120mm adjustable ride height. Adjustable at the spring perch, and shock body.
-6061 Aluminum construction with T6 for added strength.
-Forged and anodized for a superior long lasting finish.
-Optional Spring rates from 6kg/mm-24kg/mm available (add. cost).
-Adjustable for both compression and rebound.
-Mono-tube design.
-Ideal for ultimate street performance.
ok who's got these? you can get them in a bunch of spring rates it says, and they look affordable enough. Anyone using these. I had to click on the add, it is up all the damn time!
If there is a thread about this then i suck at searching, i tried it i swear. If there is, then can someon give me the link because i couldnt find anything.
Old Nov 6, 2005 | 12:34 AM
.water's Avatar
Default Re: f2 coilovers (jaydmcrx)
wow..whats up with that rear coilover design??
Old Nov 6, 2005 | 05:57 PM
jaydmcrx's Avatar
No idea, im assuming that isnt the honda application.
Old Nov 6, 2005 | 08:12 PM
slammed_93_hatch's Avatar
Default Re: f2 coilovers (zzzvtakzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zzzvtakzzz &raquo;</TD></TR><TR><TD CLASS="quote">wow..whats up with that rear coilover design?? </TD></TR></TABLE>
Looks like the people who took pictures took pictures of 2 different rear coil over setups.
Old Nov 7, 2005 | 11:31 AM
jaydmcrx's Avatar
no input ehh..?
Old Nov 7, 2005 | 07:22 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: (jaydmcrx)
def not honda the lower ones have three bolts up top. That adjustment range seems pitiful
Old Nov 7, 2005 | 09:49 PM
Default Re: (cbmprelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbmprelude &raquo;</TD></TR><TR><TD CLASS="quote"> That adjustment range seems pitiful</TD></TR></TABLE>
how can you say this? it 'says' it has 24 clicks of adjustment, that could mean that there isn't much of a range at all, or that there is a huge adjustment range. Unless this are somthing of a new bread, most of the coilover who offer this "xx way adjustment" really don't have **** for an adjustment range (like D2's and others). But don't make a claim about the shocks adjustment range untill you see the a dyno.
Old Nov 7, 2005 | 10:27 PM
sirg-vtec's Avatar
Default Re: (slammed_93_hatch)
The bottom two doesn't look strong to me. It is actually scary. Say no to drugs.
Old Nov 8, 2005 | 09:37 AM
PIC Performance's Avatar
Doesn't even specify "clicks". Could be another type of infinitely adjustable ones, though I don't know why they bother to state any amount of damping levels at all.
We've found that with this design, big adjustment ranges are one cause of shoddy damping curves and inefficient adjustments.
Old Nov 8, 2005 | 09:55 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (PIC Performance)
I would like to see how these are adjusted in 24 different "ways". I'm picturing 24 differnt ***** all over the shock that all do the same thing... LOL!
Modified by 94eg! at 8:12 AM 11/9/2005
Old Nov 8, 2005 | 10:01 AM
Default Re: (94eg!)
Its like Penske 8770... x8. Awesome.
Old Nov 8, 2005 | 07:22 PM
archmage's Avatar
Heh, now clue me in... Is that a good thing or what?
Penske, Moton, blah = baller; but could be referring to specific useless model or something
Old Nov 8, 2005 | 07:28 PM
Default Re: (archmage)
No I was being sarcastic.
While Penske's 8770 series are no doubt "good", I was only referencing them due to them being truly 4-way adjustable, while most other coilovers with "ways" of adjustment really mean to say "levels", ie. the coilovers that the OP was referring to.
Old Nov 9, 2005 | 02:32 AM
archmage's Avatar
ahh, understood
It was a direct response to the post above yours then, gotcha
1320fuel.com
Jan 21, 2014 03:04 PM
SpeedRacerEX-R
Jul 31, 2006 04:33 PM
i0o0ll0o0i
Suspension & Brakes
Apr 27, 2006 02:01 PM
bogus_ek
Nov 21, 2003 10:56 AM
91SiKen
Mar 5, 2002 06:34 PM
