using 82.55mm HG with 81mm ish bore block?
Old Nov 5, 2005 | 09:08 PM
turbotime's Avatar
Default using 82.55mm HG with 81mm ish bore block?
I have a b17 and i measured the bore witha micrometer and it read as 81mm ish (im not the best with a micrometer...).
Anyway, i was running a SCE copper heagasket, 0.043" thick. The only SCE gasket in the spec for my engine is for 82.55mm bore.
So can a 82.55mm bore gasket be used with a 81mm bore engine?
Old Nov 5, 2005 | 10:44 PM
turbotime's Avatar
bump
f1 vtec
Jul 15, 2020 02:47 PM
b16 matt
Dec 4, 2005 04:17 PM
Appleton21
Aug 31, 2005 10:02 AM
Merilious
Aug 12, 2004 12:00 PM
torr
Jan 28, 2003 07:53 AM
