no spark...mpfi swap
Old Nov 5, 2005 | 05:52 PM
mattie_96's Avatar
Default GOT SPARK>>>>>BUT REVIN HIGH(5500rpm)
go down to latest
Modified by mattie_96 at 1:03 PM 11/6/2005
Old Nov 5, 2005 | 07:19 PM
mattie_96's Avatar
Bump this baby up please
Old Nov 5, 2005 | 10:36 PM
sidewayz32's Avatar
Default Re: (mattie_96)
check for continuity between certain terminals of the ignition switch. the terminals are in the honda manual http://www.honda.co.uk/owner/CRXManual/
Old Nov 6, 2005 | 12:25 AM
mattie_96's Avatar
Default Re: (sidewayz32)
thanks , really check that site out good. Also what i noticed is that the white/black wire from the 50amp fuse goes to the bat-a.....then the black.yellow wire from starter.......goes to the coil....and when I had the ignition swtich to the setting before the starter engages...the wire that comes comes from a plug on the starter....was not showing any power...then again the coil only gets power on ignition 1 mode..so.....maybe that is sort of related..but i will do more checking as i know im getting closer
Modified by mattie_96 at 1:39 AM 11/6/2005
Old Nov 6, 2005 | 12:03 PM
mattie_96's Avatar
OK I figured out the wiring issue, it was very stupid and i dont wanna mention it yet until everything is fine.
But now the car starts but still revs (WITH THE THROTTLE CLOSED) up to 5500rpm by itself
I blocked off a few vacuum lines off the TB but nothing, same reving. I am looking for some bolt holes on the manifold now that might have vacuum passages or something. I cant really find and unplugged hoses..but im sure its Gottta be a big one if it can rev to 5500 rpm +.
What in the world else could it be....IM positive someone had to of had this happen before...anyone?????
Old Nov 6, 2005 | 01:50 PM
Hondacivic90ed's Avatar
swap the tps wires
Old Nov 6, 2005 | 02:06 PM
mattie_96's Avatar
i wish it was that easy..did that already
Old Nov 7, 2005 | 07:20 AM
sidewayz32's Avatar
here's a good link for idle troubleshooting
http://www.ef-honda.com/ben/Badidle.php
Old Nov 7, 2005 | 08:41 AM
mattie_96's Avatar
thanks sidewayz, I was just there,,,and that is what this one mechanic told me, however on my civic I dont have the type of FIV under the TB, i already tried everything with mine
Old Nov 7, 2005 | 08:46 AM
YoshiLegend's Avatar
check your vaccum lines for the high idle
Old Nov 8, 2005 | 07:29 PM
Civic138's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattie_96 &raquo;</TD></TR><TR><TD CLASS="quote">thanks sidewayz, I was just there,,,and that is what this one mechanic told me, however on my civic I dont have the type of FIV under the TB, i already tried everything with mine</TD></TR></TABLE>
sometimes the FIV is on the back of the intake mani
Old Nov 8, 2005 | 07:56 PM
MattsHatch93's Avatar
Default Re: GOT SPARK>>>>>BUT REVIN HIGH(5500rpm) (mattie_96)
also check for an intake mani gasket leak....
Old Nov 8, 2005 | 10:57 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: GOT SPARK>>>>>BUT REVIN HIGH(5500rpm) (MattsHatch93)
make sure u didnt forgret any hoses. i almost forgot the brake booster hose. also did u get a new IM gasget? if not thats your problem. it's only like $8 at napa. also ceck the FIV is not shorted or unplug it and check the TB and EACV gasgets.
Old Nov 9, 2005 | 01:15 PM
mattie_96's Avatar
YUP!!!!it was the intake manifold gasket and NEVER INSTALL THE MANIFOLD BRACE first because you will get the biggest vacuum leak in history...always install the manifold first and have all the bolts tight....then elongate the 2 bottom holes of the rear brace and then try your best to install it...
Old Mar 13, 2008 | 02:29 PM
manuelesr's Avatar
so what was the deal with the wires????!!!!!!!! how did you get it to spark help please!!!!!!
BiG_DeE
Audio / Security / Video
Jul 21, 2010 07:18 AM
jnemci
Jan 11, 2010 06:16 PM
drtysohc
15
Sep 29, 2007 11:42 AM
Mandeep
Jul 11, 2005 08:54 AM
