Built Turbo jdm B18c Type R Swap Help
Old Nov 5, 2005 | 04:30 PM
93-civic-cx's Avatar
Default Built Turbo jdm B18c Type R Swap Help
ok here is the information the dealer gave me on the engine i just bought.. i am swaping it into a 1993 honda civic cx hatch. i need to know what else i will need to get this in and in use. i am going to have 5 days to drop it in and make sure it works before i have to accept it. if it doesn't work i can reject it within the 5 days and get my money back. so i need to know what all i am going to have to have on hand to do this.. here is the info...
This is a 1998 Integra Type r (B18C), not GSR.
The motor has 48,000 original miles on it and only
1,000 after it was built. This motor has been fully
built for the turbo kit that is on it. included is everything
needed including the wire harness, axles and type r ecu. (told me ecu is obd2a so i will need an obd2a - obd1 adapter) <- that much i know
Head:
1998 Integra Type r
3 angle valve job
Ported and Polished
Sufaced head
AEM power pullys
Edelbrock victor x intake manifold
Hondata heatshield intake gasket
Crower turbo cams
AEM tru-time came gears
Dual valve springs and retainers
Titanium vavles
Block:
1998 Integra Type r
Bored and Honed
Sufraced block
Arias 9:1 compression racing pistons
Arias racing rings
Eagle H-beam racing rods
Nuformz block guard
Tranny:
1998 Integra Type r Hydo (LSD)
ACT 6 puck dual diaphragm racing clutch
Short shifter
Fuel System:
Walbro 255 fuel pump
AEM fuel pressure regulator
AEM fuel rail
RC 550cc racing injectors
Hondata S200 fuel management w/boost
Turbo Kit:
Rev Hard T3/T04E Hybrid turbo
Rev Hard Intercooler
Deltagated wastegate
Vortec blow off valve
2.25” aluminized bent piping
2.5” down pipe
tubular race manifold
Steel braided –3 oil line
High pressure silicone hose
Greddy boost gauge
Greddy turbo timer
Greddy boost controller
that is the info he gave me.. here are the images i have of it..
so what else do i need to get this rolling? i have all the tools i need... i am just thinking like the technical.. (wiring, ext...)
thanks everyone
Modified by 93-civic-cx at 9:50 PM 11/5/2005
Old Nov 5, 2005 | 04:36 PM
revvin9k's Avatar
Default Re: Built Turbo jdm B18c Type R Swap Help (93-civic-cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93-civic-cx &raquo;</TD></TR><TR><TD CLASS="quote">so what else do i need to get this rolling? i have all the tools i need... i am just thinking like the technical.. (wiring, ext...)</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93-civic-cx &raquo;</TD></TR><TR><TD CLASS="quote"> included is everything
needed including the wire harness</TD></TR></TABLE>
Just wanted to ***** your bay and setup..which is a nice setup BTW.
Old Nov 5, 2005 | 08:29 PM
Sleepy_Red_hatch's Avatar
Default Re: Built Turbo jdm B18c Type R Swap Help (SMOKEALOTAPOTAMUS)
your going to need the harness adapter (http://www.rywire.com) and your probably going to need a new turbo manifold if thats an SS auto Junk i spy
Old Nov 5, 2005 | 08:52 PM
can i use my stock civic harness with an obd2 - obd1 adapter.. and what do you mean by an SS auto Junk? explain farther..
Old Nov 5, 2005 | 09:11 PM
eK9aT10pSi's Avatar
Default Re: (93-civic-cx)
the turbo manifold which will start cracking soon if not already
Old Nov 6, 2005 | 12:23 AM
dpetro1's Avatar
Default Re: (eK9aT10pSi)
first thing i thought when i saw that pic was SSAC. ive heard so much bad stuff about those manifolds and then i went to inlinepro today and they had 2 sitting side by side ( they dont sell them they wee just for demostration). one was brand new and the other was 2 months old. on the latter the wastegate had completely cracked off and there was a huge hole in the side if the mani.
other than that it looks like a nice setup
Old Nov 6, 2005 | 06:22 AM
well ok.. what mani would you guys suggest i get to replace this one? but other than the mani, i should have everything i need?
Modified by 93-civic-cx at 8:08 AM 11/6/2005
Old Nov 6, 2005 | 06:29 AM
ej8luver's Avatar
they aren't talking about the intake manifold..they are talking about your cheap exhaust manifold for the turbo!
Old Nov 6, 2005 | 07:08 AM
read between the lines.. you knew what i meant.. hehe
Old Nov 6, 2005 | 11:04 AM
dpetro1's Avatar
there are plenty of good manifold companies. you could look into spoolin performance, one-fab, neukin, full race (if you have the cash). or you could even get a log type like the inlinepro (cast stainless will never crack). just be aware that of you change your manifold then you will mostly likely need to change your downpipe and maybe tweak the intercoller piping.
digitalightkenz
Nov 30, 2011 07:57 AM
The_Flatman
10
Jun 8, 2010 12:49 PM
jdmb18c-hatch
Nov 24, 2009 07:27 AM
blumeany
Jan 1, 2005 08:21 PM
Papichulo1767
Jul 13, 2004 01:28 PM
