broken clutch pedal
Old Nov 5, 2005 | 03:14 PM
BrokenRex
Guest
Posts: n/a
Default broken clutch pedal
Alright, yesterday just turning the corner to getting to my buddies house i drop it into 2nd, and my clutch just hits the floor.... Im thinkin my clutch cable finally unraveled, but it was actually the cylinder bar connected to the pedal, and a plate (plate/cylinder part) had broken, and it looked like it was not at all suppose to do that, only fixable way from my eyes is get whatever this is.... anyone know?
Old Nov 5, 2005 | 04:09 PM
SiR Inspired ED7's Avatar
Default Re: broken clutch pedal (TuRdCrX)
I think you broke this part. The clutch side... Mine has broken once too i just got one from the junk yard for like 10 bucks
Old Nov 5, 2005 | 05:17 PM
88crx-si's Avatar
damn...this happened to me 3 times!
i never got it replaced, i just got it welded. first it broke on the left of the pedal, then it broke on the right, then it broke right in the middle! i think mines going to hold up now...
Old Jan 21, 2006 | 04:03 AM
crxnj's Avatar
Default Re: (88crx-si)
Happend to me also but people says its due to my stage 3 pressure plate and 6 puck clutch..Seems like honda screwed up..Because its pretty messed up when you're driving and the damn clutch pedal just falls.
Old Jan 21, 2006 | 04:32 AM
shadycrx's Avatar
Default Re: (Mr.speaker)
i actually know exactly what your talking about and how to fix it but i just read your arab-hating post about 30 mins ago and deff dont want to help you now
Old Jan 21, 2006 | 10:21 AM
2kTeg's Avatar
Default Re: (shadycrx)
i've been threw 3 of these things, honda deffinitally screwed up. its a PITA to replace also, have fun
Old Jan 21, 2006 | 10:38 AM
CRXb18Turbo's Avatar
Default Re: (2kTeg)
guess he got ban...
Old Jan 21, 2006 | 10:42 AM
.Thomas's Avatar
Default Re: (2kTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadycrx &raquo;</TD></TR><TR><TD CLASS="quote">i actually know exactly what your talking about and how to fix it but i just read your arab-hating post about 30 mins ago and deff dont want to help you now </TD></TR></TABLE>
This is true
Old Jan 21, 2006 | 11:13 AM
jdm206's Avatar
Default Re: (flatblkCR-X)
yeah i had the same problem as you and i want to know how to fix this to?
Old Jan 21, 2006 | 12:38 PM
Super79Dave's Avatar
Default Re: (jdm206)
There was a thread about this earlier on the differences between the SI bracket and the DX CX bracket. The Si is much stronger and has a mounting point for a clutch start switch.
https://honda-tech.com/zerothread?id=1470034
heres the thread link
Old Jan 21, 2006 | 01:33 PM
FOMULA91's Avatar
Default Re: (Super79Dave)
Damn, do you guys SLAMMMM the pedal or what?
BTW he did get BAN.
Old Jan 21, 2006 | 03:03 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx-si &raquo;</TD></TR><TR><TD CLASS="quote">damn...this happened to me 3 times!
i never got it replaced, i just got it welded. first it broke on the left of the pedal, then it broke on the right, then it broke right in the middle! i think mines going to hold up now...</TD></TR></TABLE>
That is what I was going to say, I would see this from time to time on Hondas and welding it always worked like a charm! but $10 for a replacement is tempting as well. Maybe buy the replacement and weld it before install to give it extra strength!
Old Jan 21, 2006 | 03:59 PM
jdm206's Avatar
Default Re: (VtecSyndrome)
yeah i was just wondering if hatchback pedals would fit in my sedan? can i just take out the clutch pedal by itself and not take out the whole pedal assembly?
Old Jan 21, 2006 | 04:01 PM
BlueCrxNC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">That is what I was going to say, I would see this from time to time on Hondas and welding it always worked like a charm! but $10 for a replacement is tempting as well. Maybe buy the replacement and weld it before install to give it extra strength!</TD></TR></TABLE>
That's exactly what I did for me and a few other CRX owners locally. We went out and purchased 'new' used pedal assemblies and had reinforcements welded in. If you use a stiffer aftermarket pressure plaste, do yourself a favor and take the assembly out and get it fixed up. Once the unit snaps, that's it. It's very difficult to bend the metal straight enough to weld it back up and fix it. A warning sign that your assembly is tearing/breaking is a squeaking noise while applying the clutch pedal.
Honda should have known better than to have used such thin metal.
Pic of the first one I ever had fixed... We used a square 1/4" thick steel plate on the back side of the right part of the clutch's frame. (unseen)
Modified by BlueCrxNC at 8:27 PM 1/21/2006
ehLAaay
Transmission & Drivetrain
Aug 3, 2011 06:37 PM
TRE_
12
Jan 21, 2003 05:48 PM
MrSmith
Sep 28, 2001 08:30 PM
