how to remove hood emblem?
Old Nov 5, 2005 | 02:14 PM
aws140's Avatar
Default how to remove hood emblem?
i want to remove the hood emblem from my car and install the front grill with the hood emblem. to remove the hood emblem do i just pop it off? i tried to look from inside the hood for where the emblem comes through but i couldnt find the two holes. i just want to make sure so i dont mess anything up. thanks
94 accord LX
Old Nov 5, 2005 | 02:20 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: how to remove hood emblem? (aws140)
Yes, just pry it up. But, do it slowly to avoid scratching the paint around the emblem.
What I did before, was to first wax the area, to help prevent scratches. Then I use my hands and a plastic wedge and slowly worked at it.
Oh yeah, I also used a small piece of cloth under the plastic wedge to also help prevent scratches.
Old Nov 5, 2005 | 02:25 PM
P_Adams's Avatar
Your '94-'95 Honda Hood Emblem is held on by two studs held by two barrel clips. (refer included link to illustration.)
http://www.hondaautomotivepart...ABELS
What you do with the two remaining holes is up to you
P
Old Nov 5, 2005 | 02:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: how to remove hood emblem? (P_Adams)
If you pry the emblem off, you can either leave the studs in or also pry them out. But if you pry the studs out, you are left with two holes.
Either way, its up to you what you want to do with it.
Old Nov 5, 2005 | 04:02 PM
aws140's Avatar
yeah i know the holes will be there. i plan on getting the whole car painted in the near future so i figured id take the badge off and leave the studs in for a little bit then get the wholes filled with bonda and smoothed over. after it gets painted you wont be able to tell the badge was ever there
Old Nov 5, 2005 | 05:35 PM
sparknblaze's Avatar
Default Re: (aws140)
I just pulled mine off. I didn't have any problems with paint chipping or anything like that. It was easy off both front and back. I did mine with my fingers. You may want to use a screwdriver if you are delicate and don't want to chip a nail.
Old Nov 5, 2005 | 07:23 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (sparknblaze)
Just find someone with a 96-97 that would be willing to swap you hood and grill
MakeYourSelf
Honda Civic (2006 - 2015)
14
Jan 18, 2010 09:32 PM
Bro. Darkness
Paint and Body
Jan 14, 2008 12:53 PM
Takashi1978
Dec 28, 2005 12:41 PM
slvrcivic97
Jul 11, 2003 11:43 PM
au-gsr
Dec 6, 2002 09:48 PM
