not dealing with roll pin
Old Nov 5, 2005 | 11:15 AM
Mavrick's Avatar
Default not dealing with roll pin
hey, since i cannot remove that bitch pin and i cannot get a wrench on the through nut that holds the shift linkage to the shifter, is it possible to drop the transmission without bending the shift rod?can i keep all shift linkage in place when i do it?
Old Nov 5, 2005 | 11:18 AM
sickerhatch's Avatar
Default Re: not dealing with roll pin (Mavrick)
ya I've done it before just drop it strait down.
Old Nov 5, 2005 | 11:25 AM
Mavrick's Avatar
Default Re: not dealing with roll pin (sickerhatch)
so it was ok when you did the clutch? could you move it far enough to do the clutch?
Old Nov 5, 2005 | 08:47 PM
Cuda70's Avatar
Yeah you will have enough room.
Plus once you drop the tranny a little, you should be able to get a wrench on that rear bolt to the shifter.
Old Nov 6, 2005 | 10:47 AM
BigMoose's Avatar
This doesn't answer your question directly, but I remove the bitch pin with an air chisel and a machined pin type punch on the end of it. You could grind an over the counter air chisel tool if you took the time to fit.
Old Nov 6, 2005 | 03:11 PM
dfoxengr's Avatar
Default Re: not dealing with roll pin (BigMoose)
8mm straight punch works great.
Old Nov 7, 2005 | 09:30 AM
Chiovnidca's Avatar
Default Re: not dealing with roll pin (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">8mm straight punch works great. </TD></TR></TABLE>
8mm air chisel works better.
gursh d
14
Sep 18, 2007 09:48 AM
Vtec4me
Sep 13, 2007 05:58 AM
redboost10
Jul 22, 2007 06:58 AM
skata89
Mar 27, 2006 09:52 PM
made in JAPAN
Jan 31, 2003 08:22 PM
