Setting at TDC
Old Nov 5, 2005 | 11:11 AM
KL14's Avatar
Default Setting at TDC
My engine came without a lower timing belt cover. I've been looking (the pistons seem to be as close to tdc as they could be. I looked on the timing belt crank sprocket and it has a little notch in it too and this notch is lined up with an arrow on the oil pump. Is that another way to line up to TDC without using the crank pulley and lower timing belt cover?
Old Nov 5, 2005 | 01:55 PM
Mikey3000's Avatar
Default Re: Setting at TDC (KL14)
if its a dual cam motor there should be a pointer on the flywheel side of the block pointing to the TDC mark on the flywheel. oh, is it a dot on your crank sprocket? that dot is supposed to line up with the arrow on your oil pump, yes.
Old Nov 5, 2005 | 05:50 PM
KL14's Avatar
Default Re: Setting at TDC (Mikey3000)
Nah, it's not a dot, there's actually a grove on one of the teeth, but only one, and it looks purposeful (because it's not in a place that would mess up the timing belt)
Old Nov 7, 2005 | 09:11 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KL14 &raquo;</TD></TR><TR><TD CLASS="quote">Nah, it's not a dot, there's actually a grove on one of the teeth, but only one, and it looks purposeful (because it's not in a place that would mess up the timing belt)</TD></TR></TABLE>Yes, that's a TDC mark which lines up with the arrow on the oil pump.
ThA IntegrA HI
Dec 17, 2009 06:37 PM
jdmthug
Aug 22, 2009 07:09 AM
dc2leftovers
Dec 10, 2006 08:15 AM
Concept Tuning
Jun 29, 2006 06:33 PM
deSigi
May 15, 2005 06:46 PM
