OBD2B vs OBD2A cel's
Old Nov 5, 2005 | 08:55 AM
kobeRy_si's Avatar
Default OBD2B vs OBD2A cel's
im probably going to get flamed hardcore, but I need other people's input.
Im running a 98 B18C(R) in my 99EM1. To get my car running correctly, I use a obd2B to obd2A harness then my p73 ECU. But when, that ECU is in, I always get the knock sensor cel (23).
Now, when I put my P2T obd2B ECU in, I get the usual 54 and 22 cel's because my obd2a motor lacks those sensors. But what I dont understand is, why doesn't the knock sensor cel go off anymore? Are knock sensors specific to only certain obd's? Did I buy a faulty ECU?
Any help is appreciated. Thanks.
Old Nov 5, 2005 | 10:03 AM
kobeRy_si's Avatar
Default Re: OBD2B vs OBD2A cel's (kobeRy_si)
Old Nov 5, 2005 | 10:06 AM
poison's Avatar
The reason knock sensor is throwing for the OBD2a is because the location is different. Check using a digital multimeter. It might be the jumper harness.
KS for OBD2b is C3
KS for OBD2a is D6
good luck.
Old Nov 5, 2005 | 11:15 AM
kobeRy_si's Avatar
Default Re: OBD2B vs OBD2A cel's (poison)
kewl, thanks for the info.
Modified by kobeRy_si at 12:26 PM 11/5/2005
89LSED
31
Jan 30, 2011 04:54 PM
1320king
10
Sep 23, 2007 06:36 PM
shatchi
17
Feb 1, 2005 10:00 AM
b18crx
Mar 30, 2004 11:36 AM
