custom fuel feed hose
Old Nov 5, 2005 | 08:43 AM
tmoney1421's Avatar
Default custom fuel feed hose
ok so im doing a jdm h22 swap into my si lude and everything is just about finished, the only dilema i have is the fuel line. as i understand both the si and vtec usdm models have the connector for the fuel feed line on the left side of the fuel rail, while the jdm has it on the right. is there anyway to avoid swapping in a different fuel rail and modify the existing h23 line/create a custom line to connect? thanks a lot for any help
p.s when i searched all i found was info on actually changing the fuel rail to h23
Old Nov 5, 2005 | 01:14 PM
tmoney1421's Avatar
Default Re: custom fuel feed hose (tmoney1421)
i know someone has to have went through this cmon
Old Nov 5, 2005 | 01:49 PM
MadCityLude
Guest
Posts: n/a
I used my stock F22 fuel rail with the H22 injectors. I couldn't mount it though so I zip tied it. Now I have an AEM, but as a temp it worked fine.
Good Luck
lutherd300
Jan 23, 2008 06:34 PM
CGags13
Mar 1, 2006 06:24 AM
bb4socal
Nov 20, 2005 01:38 PM
98HB
Mar 25, 2003 02:37 PM
poison
Sep 8, 2002 11:10 PM
