wheel bearing question
Old Nov 5, 2005 | 06:10 AM
SL0WEGG's Avatar
Default wheel bearing question
so i need to replace my front wheel bearing but i was just wondering if i should grease it first. well the machine shop is going to do it for me should they grease it? how would you even take the dam thing apart? haha i tried to pull it apart with my hands but it just doesnt work . should i just leave it up to the machine shop to grease? or does it not even need to be greased up at all? TIA
Old Nov 5, 2005 | 06:48 AM
Frozen E's Avatar
H-T White Ops
It should come pre-greased. Don't try to take it appart. Just leave it.
Old Nov 5, 2005 | 06:53 AM
poison's Avatar
Default Re: wheel bearing question (boostedej1)
Leave it up to the machine shop if they are doing it.
Old Nov 5, 2005 | 07:12 AM
SL0WEGG's Avatar
Default Re: wheel bearing question (poison)
perfect! any tips on breaking free the lower ball joint? **** is a pain in the ***
Old Nov 5, 2005 | 07:13 AM
poison's Avatar
easy as hell.
take out the dust shield and press it out using a hydraulic press. comes right out.
Old Nov 5, 2005 | 07:19 AM
Luserkid's Avatar
Theres also an easier way of lifting the wheel and sticking a 1/2 ratchet back there and then kicking the disc.
Old Nov 5, 2005 | 07:31 AM
SL0WEGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">easy as hell.
take out the dust shield and press it out using a hydraulic press. comes right out. </TD></TR></TABLE>
that would be nice if i had one in my garage . i dont know if you understood me, i meant breaking it free from the lower control arm . i really dont feel the need to take out the whole knuckle and take it to them. well im actually fixing the wheel bearing on the driver side and the lower control arm inner bushing on the passenger side
Old Nov 5, 2005 | 07:39 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">
that would be nice if i had one in my garage . i dont know if you understood me, i meant breaking it free from the lower control arm . i really dont feel the need to take out the whole knuckle and take it to them. well im actually fixing the wheel bearing on the driver side and the lower control arm inner bushing on the passenger side </TD></TR></TABLE>
my bad. grab a hammer. pick up on the hub, and have someone hit the lca with a hammer. I do not recommend using a pickle fork or any thing that would tear the lower ball joint boot.
Old Nov 5, 2005 | 07:58 AM
SL0WEGG's Avatar
i jacked up the brake disc with a stock jack and ive been pound on that **** for the longest. haha i need a bigger hammer
Old Nov 5, 2005 | 08:01 AM
SL0WEGG's Avatar
would something like this work?
http://www.partsamerica.com/Pr...72069
Old Nov 5, 2005 | 08:33 AM
SL0WEGG's Avatar
after searching the archives found a video. this is by far the best technique eVaRRR!! worked the first time
Old Nov 5, 2005 | 12:48 PM
jdmallstar2000's Avatar
do you guys know if that slows you down?!?! cuz my front hub bearing makes an anoying sound when im at high speed and turn right.
Old Nov 5, 2005 | 05:56 PM
Frozen E's Avatar
H-T White Ops
Default Re: (jdmallstar2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmallstar2000 &raquo;</TD></TR><TR><TD CLASS="quote">do you guys know if that slows you down?!?! cuz my front hub bearing makes an anoying sound when im at high speed and turn right.</TD></TR></TABLE>
Is it a grinding/rubbing sound? If so, it's on it's way out.
Old Nov 5, 2005 | 06:06 PM
si0385.'s Avatar
Default Re: (IslandSi)
if its a good machine shop that knows what its doin they will hook you up with a grease job
Old Nov 6, 2005 | 01:23 AM
its a rubbing/humming sound..its really anoying.
ZexyAccord
Honda Motorcycles
May 31, 2007 05:27 PM
slowly slipping away
May 5, 2007 07:45 AM
wrx'n you
Sep 16, 2006 11:30 AM
hondaracin24
Jul 2, 2006 06:08 AM
Greyout
Dec 3, 2001 07:28 PM
