B20 manual transmission fluid + GM Syncromesh
Old Nov 4, 2005 | 06:00 PM
Schurke's Avatar
Default B20 manual transmission fluid + GM Syncromesh
I am sort of new to this, and the search did not answer my questions or too many threads existed with too much information... again sorry for my uneducated question.
Before winter comes, I need to replace my transmission fluid in my 1999 CRV with manual transmission. I am getting some 1st and 2nd gear grind (minor) and was going to go with GM Syncromesh transmission fluid.
How many quarts should I buy for my transmission?
What is my transmission code (too lazy to look, might as well ask)?
I'll be following directions from the Haynes book, but was wondering if you guys had any suggestions. First time doing this. Thanks
Old Nov 4, 2005 | 06:32 PM
Schurke's Avatar
Default Re: B20 manual transmission fluid + GM Syncromesh (Schurke)
bump
Old Nov 4, 2005 | 07:49 PM
nocturnaldragon's Avatar
Check your book to be sure but if its the same as my D series its 2 qts, as for the code I have no Idea Im a D series guy when it comes to trans. You shouldent need it when buying Syncro-Mesh.
Old Nov 5, 2005 | 09:04 AM
Schurke's Avatar
Default Re: B20 manual transmission fluid + GM Syncromesh (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Check your book to be sure but if its the same as my D series its 2 qts, as for the code I have no Idea Im a D series guy when it comes to trans. You shouldent need it when buying Syncro-Mesh.</TD></TR></TABLE>
i know, i was just wondering for future reference.
Old Nov 5, 2005 | 02:12 PM
Schurke's Avatar
bump
Old Nov 5, 2005 | 02:13 PM
IT'S ME DAVID's Avatar
NooB
make sure you get the gm synchromesh friction modified.
Old Nov 5, 2005 | 03:04 PM
Schurke's Avatar
Default Re: B20 manual transmission fluid + GM Syncromesh (K SERIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K SERIES &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get the gm synchromesh friction modified.</TD></TR></TABLE>
explain
Old Nov 5, 2005 | 04:08 PM
Schurke's Avatar
bump.. im doing this tomorow need info
Old Nov 5, 2005 | 07:04 PM
Schurke's Avatar
bump... i see you guys like answering "Hey what color should I paint my car?" and "What swap should I do?" questions rather then actual technical questions such as this.
Old Nov 5, 2005 | 07:17 PM
Default Re: (Schurke)
hey Ive been asking for help with some stuff for a week and havent gotten a decent response, its the way this forum works. You have a FEW people who know what there talking about and hardly post and the rest is people who dont know and post a lot.
Old Nov 5, 2005 | 07:34 PM
Schurke's Avatar
Default Re: (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">hey Ive been asking for help with some stuff for a week and havent gotten a decent response, its the way this forum works. You have a FEW people who know what there talking about and hardly post and the rest is people who dont know and post a lot.</TD></TR></TABLE>
this is a technical forum, and this thread got 96 views so far, and im sure at least 10 of those people did this before and have recomendations, but yet they seem to ignore these threads and go off to their "what color should i paint my car?" threads... which in my opinion are rediculous. http://www.vwvortex.com is a great resource for my vw needs, and they are extremely helpful (at least the mk2 forum) and HT should take a note of that. anyway now back to my question...
Old Nov 6, 2005 | 01:19 PM
Schurke's Avatar
you all suck
Old Nov 6, 2005 | 01:47 PM
peacexisxfree's Avatar
buy 4. youll have extra. now you can stop bitching.
Old Nov 6, 2005 | 02:48 PM
The Destroyer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schurke &raquo;</TD></TR><TR><TD CLASS="quote">
I'll be following directions from the Haynes book, but was wondering if you guys had any suggestions. First time doing this. Thanks </TD></TR></TABLE>
How about you go look it takes 2 seconds.
Look at your owners manual for how much fluid to put in.
Drain from drain bolt, put drain bolt back in, remove VSS and fill through there, and then put the vss back in.
Old Nov 6, 2005 | 05:52 PM
Schurke's Avatar
Default Re: B20 manual transmission fluid + GM Syncromesh (Vtaaak y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">How about you go look it takes 2 seconds.
Drain from drain bolt, put drain bolt back in, remove VSS and fill through there, and then put the vss back in. </TD></TR></TABLE>
thank you... finaly
Old Nov 6, 2005 | 06:11 PM
my_slow_civic's Avatar
You said it yourself. You're too lazy to do it for yourself. So why should we?
Don't forget to check the level, to make sure your lazy *** doesnt overfill the tranny.
Old Nov 6, 2005 | 06:17 PM
thank you... finaly</TD></TR></TABLE>
If you are unsure of how to get the fluid in through the VSS.
It is easiest to get a funnel and some hose, just think of a beerbong for your tranny fluid.
ecarfar
Honda CR-V & Element
May 2, 2017 05:26 AM
bristolhonda
Jul 31, 2014 09:37 AM
sdr85
Sep 24, 2007 12:39 AM
boostmee
Apr 10, 2007 01:11 PM
mystikz2002
Acura TL, RL & ZDX
12
Jan 20, 2005 09:22 AM
