Roll Pin
Old Nov 4, 2005 | 02:11 PM
Mavrick's Avatar
Default Roll Pin
anyone know how to remove the bitch pin from the shift linkage? it looks like the bottom part of the pin (roll pin) is larger so it can only go one way? Is this true? what side do I take it out from?
Old Nov 4, 2005 | 06:34 PM
dfoxengr's Avatar
Default Re: Roll Pin (Mavrick)
its just a spring pin. you need a punch, and an 8mm one will work
Old Nov 4, 2005 | 06:53 PM
drdisco69's Avatar
Default Re: Roll Pin (dfoxengr)
Drift punch, not tapered punch. A 10mm bolt (has 8mm threads) will work in a pinch. Watch out for your fingies!
Old Nov 4, 2005 | 06:59 PM
dfoxengr's Avatar
Default Re: Roll Pin (drdisco69)
actually the 10mm headed bolts are 6x1.00 metric, the 12mm heads are the 8x1.00's i believe.
basically he is saying a straight punch. tapered wont get it out far enough.
Old Nov 4, 2005 | 07:08 PM
drdisco69's Avatar
Oops, right you are, Kenny. Too much diff eq, not enough real world.
Old Nov 4, 2005 | 09:06 PM
dfoxengr's Avatar
ive got D.E. to take over summer
and multi next semester
Old Nov 5, 2005 | 09:53 AM
Mavrick's Avatar
wouldn't it be easier to just remove the shift linkage at the shifter? does that even have to be done?
Old Nov 5, 2005 | 01:41 PM
shorto85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't it be easier to just remove the shift linkage at the shifter? does that even have to be done?</TD></TR></TABLE>
When I did my swap I couldn't get that bitch pin out so I undid it at the shifter and pulled it out with the motor. Once it was out I then got the pin out no problem at all.
Old Nov 5, 2005 | 05:21 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">ive got D.E. to take over summer
and multi next semester</TD></TR></TABLE>
Multivariable calc = calc 3 = EZ
Diff eq is pwning me for some reason, I hate it. There's forking 9000 different ways to solve these damn problems.
Old Nov 11, 2005 | 04:51 PM
boost'd_crx's Avatar
you can use a punch pin, but i like to use the 10mm bolt. only takes about 3-4 hits with the hammer
Old Nov 11, 2005 | 06:00 PM
BigMoose's Avatar
I machined an 8mm piloted tip for an air chisel. It works like a champ.
Old Nov 12, 2005 | 07:17 AM
Chiovnidca's Avatar
Default Re: Roll Pin (BigMoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">I machined an 8mm piloted tip for an air chisel. It works like a champ.</TD></TR></TABLE>
Snap-on sells em for those without a machine shop.
Old Nov 12, 2005 | 11:00 AM
doublejz's Avatar
Default Re: Roll Pin (Chiovnidca)
air chisel all the way. but they sell chisels that will work
umair
Mar 27, 2009 03:27 PM
Joe-G
Feb 22, 2008 11:03 PM
say_xiong
Sep 21, 2006 11:34 PM
streetracerof06
Oct 27, 2005 09:20 AM
sabertooth
Jan 9, 2004 10:23 PM
