HELP!!! water/rain leak under glove box..........
Old Mar 8, 2002 | 11:56 PM
accord-euro-r's Avatar
New User
Default HELP!!! water/rain leak under glove box..........
Anyone have the same problem? How did you fix it? It seems the big metal thing under the glove box have water condensation when AC was on. Maybe water from my AC went inside the big white plastic thing beneath the glove box........... What is the white plastic cover located near the top left side of the ECU? Thks!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 8, 2002 | 11:57 PM
New User
Default Re: HELP!!! water/rain leak under glove box.......... (accord-euro-r)
Mine is a 97 teg, thks!
Old Mar 9, 2002 | 04:56 AM
vertius's Avatar
I have the same problem. I only see the water after I shut off my AC. The water pours out like a little waterfall.
Old Mar 9, 2002 | 05:10 AM
GSRaCeRbOI's Avatar
so you already checked the drain line and the heater core or maybe the sunroof drain line? i did a search and see that you asked this about a month ago..
https://honda-tech.com/zerothread?id=122656
none of these solutions helped?
Old Mar 9, 2002 | 09:20 AM
New User
Default Re: HELP!!! water/rain leak under glove box.......... (GSRaCeRbOI)
My 4 gauge wire for the stereo did go through a hole through the firewall, but it seems the water is leaking from somewhere else and stay inside the white plastic thing under the glove box.
Old Mar 9, 2002 | 10:26 AM
Chris's Avatar
Heater core is leaking....
As for the water flowing after you shut off the AC, you need to hook the drain tube back through the firewall.
Old Mar 9, 2002 | 11:01 AM
ImportHatch's Avatar
Default Re: HELP!!! water/rain leak under glove box.......... (Chris)
My heater was not working and my passenger floorboard was wet and It was my heatercore leaking.
Yager-
Old Mar 9, 2002 | 11:41 AM
New User
Is it hard to fix? thks!
Old Mar 9, 2002 | 01:29 PM
Chris's Avatar
hard to fix is a relative term! I could do it easily, but it involves emptying the radiator and removing some lines... I suggest you get a helms manual...
Old Mar 10, 2002 | 12:27 AM
New User
thks! My helms manual is coming next week. What parts did u change to fix it?
puma1077
Sep 10, 2008 09:03 PM
Grayson
Jul 16, 2005 03:14 AM
sstrom
Sep 29, 2004 12:24 PM
accord-euro-r
May 1, 2002 06:40 AM
accord-euro-r
Feb 1, 2002 05:18 PM
