Help!! Hit a pothole - whole bunch of damage...
Old Nov 4, 2005 | 11:34 AM
killah3084's Avatar
Default Help!! Hit a pothole - whole bunch of damage...
Deep bastard... As a result my i have an exhaust leak between the front pipe and the header. How do i replace the gasket?
Also There is a loud clunking noise coming from left wheel and i can feel the struggling with it. Steering wheel strays straight when i let go though. Is it the bearing? Also how do i take off the assembly in the front? Any pics, graphic instructions would be higly appreciated!
Thanks
-V-
I hate MA roads! Just like the weather new potholes appear every ten minutes...
Old Nov 4, 2005 | 11:58 AM
P_Adams's Avatar
Default Re: Help!! Hit a pothole - whole bunch of damage... (killah3084)
Listen Killah, before we go any furthur; put your car's year/make/model in the signature portion of your profile.
If I had this info, I could have given you some illustrations.
What side was hit?
Does the "Klunk occure only when you turn?
P
Old Nov 4, 2005 | 01:45 PM
killah3084's Avatar
Default 1993 honda accord lx black/silver
Klunk occurs on the left any time I'm driving and rolling straight. Stays about the same through corners. Tried roling backwards and forward - same thing. Sound like something is being snapped and chewed over there.
Old Nov 4, 2005 | 02:13 PM
P_Adams's Avatar
Default Re: 1993 honda accord lx black/silver (killah3084)
I would suggest you not screw around it here asking questions and get it looked at PRONTO.
If it's rythmic (like one 'clunk' for every wheel rotation) it could be an axle. If not, it could be a strut, control arm or broken stabalizer bar bracket/bushing.
It needs to be looked at NOW
P
Old Nov 5, 2005 | 11:48 AM
killah3084's Avatar
thanks. i'll do that.
Old Nov 5, 2005 | 12:02 PM
Thunder Cat's Avatar
khmer? lynn does have it bad,but NYC isnt all that great either. goodluck man
Old Nov 5, 2005 | 07:28 PM
YeuEmMaiMai's Avatar
it sounds like you busted a CV joint.
Old Nov 5, 2005 | 07:29 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (ThunderCat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThunderCat &raquo;</TD></TR><TR><TD CLASS="quote">khmer? lynn does have it bad,but NYC isnt all that great either. goodluck man</TD></TR></TABLE>
que????
Old Nov 6, 2005 | 08:27 AM
deserthonda's Avatar
Default Re: Help!! Hit a pothole - whole bunch of damage... (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like you busted a CV joint. </TD></TR></TABLE>
if by busted u mean BROKEN ?? that is not the case if cv joint was busted car would not be able to move .... as it was suggested ...i would remove the wheel and chk for broken , loose suspens parts ..
Old Nov 6, 2005 | 09:50 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Help!! Hit a pothole - whole bunch of damage... (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">.i would remove the wheel and chk for broken , loose suspens parts ..</TD></TR></TABLE>
Old Nov 7, 2005 | 11:09 AM
killah3084's Avatar
Got it fixed...very cheap and easy fix... One of the studs was loose causing the wheel to wobble and make a lot of noise. Took off the wheel and replaced the hub - $20 from junk yard.
Old Nov 7, 2005 | 12:31 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (killah3084)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killah3084 &raquo;</TD></TR><TR><TD CLASS="quote">Got it fixed...very cheap and easy fix... One of the studs was loose causing the wheel to wobble and make a lot of noise. Took off the wheel and replaced the hub - $20 from junk yard.</TD></TR></TABLE>
Old Nov 7, 2005 | 12:37 PM
P_Adams's Avatar
Wow. Remind me to avoid Pot Holes when driving thru Lynn.
I understand they have MUCH better Pot Holes in Revere. You're gonna have to talk to Gov Romney and insist on those upgraded Pot Holes for Lynn.
Hey, with the Big Dig project, they should be used to throwing lots' 'o' money in big holes
P
Apple395
Jan 8, 2013 05:04 PM
Bobbyt5408
Suspension & Brakes
Oct 28, 2008 07:58 AM
Tegraracer90
Apr 15, 2007 02:26 PM
1_slow_crx
Sep 1, 2006 09:46 AM
Sephro
Oct 11, 2002 10:34 AM
