LS/V parts list...suggestions?
Old Nov 4, 2005 | 11:33 AM
tegbooster's Avatar
Default LS/V parts list...suggestions?
I currently have a blown LS and im looking to do the ls/v swap instead...i've already got about half the parts but lemme know what u guys think of the list
-c1 *gsr* head port/polish/bored to match skunk2
-skunk2 stage 2pro cams/gears
-ARP rod bolts + head studs
- Cam seals
-p28 programmed w/ chrome + conversion harness
-Skunk2 Intake manifold
-AEM HF Fuel Rail
-Golden Eagle Vtec oil line conversion kit
-GSR head gasket
-Apexi VAFC
-NGK Plugs/Wires
-Skunk2 Valves/Springs/Retainers
-GSR Timing Belt
-ITR Throttle body
-ITR Fuel Pump
-*possibly pistons and rods...but most likely not*
-ITR Oil/Water pump
so for all u ls/v owners or just the knowlegable folk.....did i do good...if not...what else would i look into getting....i will be looking into turbo but not for a year or 2 down the road....so besides I/H/E i believe i got it all covered....yeaH?
Old Nov 5, 2005 | 01:09 AM
tegbooster's Avatar
Default Re: LS/V parts list...suggestions? (tegbooster)
anyone?
Old Nov 5, 2005 | 06:47 AM
dohcdelsol93's Avatar
why do you have vafc if you are using chrome?
I'd have the block looked at by a machine shop being that you have blown it. Get the crank turned and ballanced and linear bore the mains. I'd replace all the bearings in the bottom end and have the cylinders checked for cracks and make sure it doesn't need to be bored and get it honed to break in your new rings. Then once I get all the specs on your block get the internals. If your not going with aftermarket forged rods I'd get arp rod bolts for your stk rods (that need to all be checked by a machine shop due to the blowing or your engine), I'd also recommend getting either vtec pistons or forged pistons. If you plan on running stk ls pistons (I don't recommend) you have to enlarge the valve reliefs on the exh. side.
Remember to assemble your engine using plenty of assembly lube and please use a torque wrench and double and tripple check yourself on all specs. I dont have a stretch gauge too so I have to loosen and tighten the main and rod bolts 3 times before they are reay to go. Also use plasti gauge if you don't have mics and other expensive measring tools. And last but not least break your engine in with conventional motor oil I see too many engines broken in with synthetic and the rings do not seat properly, synthetic is too slick. OH and I reccomend oil press gauges.
I'd go more into detail but I gotta get back to work, hope this helps out some
Old Nov 6, 2005 | 07:01 AM
ALMXDUPINTEGRA's Avatar
What about power steering?
Old Nov 6, 2005 | 11:16 AM
tegbooster's Avatar
to the first one....
i bouht the vafc before i realized i might as well just chip the ecu so...im in the process of selling that off....and i dont know about all the block work on such a minor build....seems amost unnecessary specially when i will be getting away from the n/a fairly soon and turboing the bitch. as for the second reply.... "power steerin????" i didn't know i would have anything different w/ my power steering if i were to go thru w/ a head change....haven't read that anywhere ....if u can elaborate on that tidbit a little more would be cool
Old Nov 6, 2005 | 11:40 AM
Default Re: (tegbooster)
to keep powersteering you need the top power steering to motor mount from a vtec engine and you will re-use the bottom bracket from the LS.
You should rebuild/beef up your bottom end on your ls/vtec especially if you plan on going turbo. But everyone is entitled to their own opinion. I personally don't like the idea of my valves bouncing off of my pistons and snapping the weak stk ls rod bolts when shifting at 8,500 rpms at 12psi. It's cheaper to do things right the first time.
Old Nov 6, 2005 | 11:44 AM
Yup, ones you swap the head you'll need the power steering bracket say from a GSR.
Old Nov 6, 2005 | 12:42 PM
EFin' Kyle's Avatar
Default Re: (ALMXDUPINTEGRA)
u dont need power steering. just tough it out. i dont have PS in my CRX. its fine. and i drove my eclipse with no PS for like 50 miles and did fine.
-Kyle
Old Nov 6, 2005 | 01:18 PM
tegbooster's Avatar
haha....im assuming something like a bracket isn't too much to spring for when im spendin about 1700 total on everything....and as far as the block beef-up i've already got it setup for n/a as far as the valvetrain + cams + springs not to mention the rod bolts and head studs....so im covering my bases....but it's like another 2000 just to rebuild the block basically is what ur talking about.....i might as well just add it to the next project *turbo* and make this one a 2300 project and the turbo a 5000 project....i wish i had money lol...keep the input comin
Old Nov 6, 2005 | 01:39 PM
EFin' Kyle's Avatar
i think we all wish we had money. LOL! but yeah im planning on building up a turbo ls/vtec. good lcuk with urs i hope everything works out for u.
Old Nov 7, 2005 | 01:36 PM
JJ-Built's Avatar
Default Re: (H4 Project)
https://honda-tech.com/zerothread?id=174153.. check
Old Nov 7, 2005 | 04:25 PM
tegbooster's Avatar
hey thanks for all the infor guys...especially JJ-Built....incredibly helpful....but i think im backing out of this project and instead just turboing the LS....opinions?
Old Nov 7, 2005 | 07:12 PM
hybridpatient95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegbooster &raquo;</TD></TR><TR><TD CLASS="quote">I currently have a blown LS and im looking to do the ls/v swap instead...i've already got about half the parts but lemme know what u guys think of the list
- Cam seals
-AEM HF Fuel Rail
-GSR head gasket
-Apexi VAFC
-NGK Plugs/Wires
-GSR Timing Belt
-ITR Throttle body
-ITR Fuel Pump
-ITR Oil/Water pump
so for all u ls/v owners or just the knowlegable folk.....did i do good...if not...what else would i look into getting....i will be looking into turbo but not for a year or 2 down the road....so besides I/H/E i believe i got it all covered....yeaH? </TD></TR></TABLE>
you need to use a ls headgasket not a gsr one..
Old Nov 8, 2005 | 09:19 AM
Default Re: (frankenfiend 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">
you need to use a ls headgasket not a gsr one..</TD></TR></TABLE>
gsr head gasket will work fine. The GSR is used in the GE ls/vtec kit. I highly recomend this kit, makes the head conversion easy. It has all the hoses, tap, pancake, set screws, dowels, and head gasket.
Old Nov 8, 2005 | 01:19 PM
LS Gasket much better fit plus the dowel pins come in effect I believe
Maciel
Aug 12, 2017 07:21 AM
ninezeroteg
Jan 2, 2009 07:26 AM
aziz93
Northeast (Sales)
Dec 12, 2006 01:26 PM
Orangecivic251
Sep 28, 2006 05:30 PM
91whiteZCrex
Feb 16, 2006 09:31 PM
