What would spoon cams be compared to,other cam wise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vrex »</TD></TR><TR><TD CLASS="quote">i thought they are reground type r cams, this is said becasue spoon is a tuner not a producer right?</TD></TR></TABLE>
They are not reground cams. The Spoon cams are ground by Honda to Spoon's specifications using blank cores.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by back-door »</TD></TR><TR><TD CLASS="quote"> CTR cams</TD></TR></TABLE>
Again, the profile of the Spoon cams is most often compared with that of Toda's Spec A cams. Both are more aggressive than factory CTR cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghg78 »</TD></TR><TR><TD CLASS="quote">so would you recommend the spoons or toda c's,for a 12-1 comp.engine.</TD></TR></TABLE>
It really depends upon your goals for the motor. The Spec C's are far more aggressive than the Spoon cams.
dElSleepiE
May 9, 2004 11:55 AM
EK MONEY
Nov 17, 2003 08:57 AM
