LS to ITR w/ LSD tranny...but with OH noes!!!!111
Old Nov 4, 2005 | 10:18 AM
Platinum Playa's Avatar
Default LS to ITR w/ LSD tranny...but with OH noes***Update 1***
Hey, Honda-tech. Long time reader first time poster with some goodies. I picked up this ITR tranny for a crazy deal, but it comes with a couple of issues.
I'll be updating this thread as i go along and get the parts. So far i know i'll need new bearings, seals, countershaft and final drive. I was aware of the damage when i bought it but not to the extent, gears are still good so i can still take advange of the short geared ITR tranny. If the gears were messed it be a complete loss for another ITR but luckily it ain't that bad.
Casing ohhh ahhhhh.
So i open it up, as soon i open it i see the cancer.
^very bottom of the countershaft is fubard
so me and flexin5 pulleverything out lay it on the flo, honestly these tranny's are really basic
this link helped me out alot:
https://honda-tech.com/zerothread?id=795700
I pull this from the tranny magnet
^You can see here all the countershaft teeth..and random pieces of shrapnel lol
LSD isn't too bad, pretty banged up.I need a new final drive for sure
Pics of the countershaft
How do the Synchros look to you guys, Should i replace them or are they okay..
I've never seen worn syncros so i don't have much to go off of.
and of course the LSD in all its glory still okay
now all in all, I'm not too woried i picked it up for 6 bills CDN so even if i fix the final drive and countershaft i'll still be ahead of the 1200 CDN we usually see around toronto. Even if i did get one for 1200 all intact i would have replaced the syncros regardless so i feel good about that.
Now, do any of you guys know what i can get a coutershaft either GSR or ITR (same ****) and final drive USDM or JDM doesn't matter. Also what do you think about the synchros replace or keep these ones. Thanks for looking
********UPDATE NOV 17 2005***********
Well, i'm back. I was lucky enough to score a 4.4 Final Drive, Needle bearings, First Gear and Countershaft. After my last post i pm and e-mailed everyone i know to see if they had the parts, lucky enough the day after i asked a buddy of mine someone had went 4.7 and had this available
the same day i got it grabbed a jaw puller (gear puller) and got cracking again on this with Flexin5 and another friend my ours. Pulled all the gears off the old countershaft and slapped them on the new shaft.
you can see the comparison between the old and new countershaft...it was so fuck0rd
and a comparision between old and new final drive:
So basically what i plan do to do is contact gear speed and buy some new synchros, and from acura continue with new bearing, seals, nuts and washers.
I've also decided on buying a stage 1 clutch and lightened flywheel since everything will be pulled off anyway.
any recommendations, comments positive and negative are cool
Modified by Platinum Playa at 9:14 PM 11/16/2005
Modified by Platinum Playa at 9:15 PM 11/16/2005
Old Nov 4, 2005 | 11:44 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: LS to ITR w/ LSD tranny...but with OH noes!!!!111 (Platinum Playa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Platinum Playa &raquo;</TD></TR><TR><TD CLASS="quote">Now, do any of you guys know what i can get a coutershaft either GSR or ITR (same ****) and final drive USDM or JDM doesn't matter. Also what do you think about the synchros replace or keep these ones. Thanks for looking </TD></TR></TABLE>
Wow, good luck with that. Damn, what the hell happened to that tranny.
I'm sure my LS looked like that inside when my ITR LSD grenaded inside it, but I couldn't even open it because the C-clip disappeared. It must have vaporized or something. I sold it for about $50 to HT user "CHEETAH".
Anyway, good luck with that. As for finding a 4.400 countershaft, just try and post a wanted ad in the Honda Marketplace here (www.hondamarketplace.com). That's where I got mine. I got it from a Honda-tech member for $75 about 4 years ago.
Unfortunately, you can't post there yet until you're a member for 14 days. Try contacting a moderator to see if they can help you out with the posting. Perhaps you can also PM CHEETAH because he rebuilds trannys. However, same deal with that. You have to become a "regular user" before you're allowed to use the PM feature.
Old Nov 4, 2005 | 02:42 PM
Dogginator's Avatar
Daisy... Daisy...
You might as well install the 4.785 FD since you need the countershaft and ring gear anyway.
Old Nov 4, 2005 | 03:09 PM
blkb18's Avatar
from the pics the syncros look pretty good, good luck with the rebuild!
Old Nov 4, 2005 | 03:40 PM
kchungb17a's Avatar
Default Re: LS to ITR w/ LSD tranny...but with OH noes!!!!111 (blkb18)
Agreed, the synchros are looking good. You can tell by looking at the "pent roof" of each of the teeth. That "top of the roof" edge should be nice and crisp (red arrows). If it's flattened are mashed, then they're toast. And I second the 4.7 JDM final drive recommendation
What did happen to that tranny?!?!?!
Old Nov 4, 2005 | 04:07 PM
mattcivic's Avatar
Default Re: LS to ITR w/ LSD tranny...but with OH noes!!!!111 (kchungb17a)
WOW! thats cool atleast it didnt blow a chunk out of the case. be sure to check the sleeves as well i just re-did my tranny my car was falling out of 5th gear going down the freeway all the suncros looked great but the sleeve for 5th/reverse was fucked took it to my machinest and he shaved the burr off it for me and put nice new points on it works great now no more falling out of gear. cant u buy an aftermarket main shaft? oh well NE ways goodluck on the rebuild if u do go and buy some syncros and bearings i recomend gear-speed hella nice and they can get ya everything u need in one shot hell maybe they can get you other misc tranny parts u need
Old Nov 4, 2005 | 04:48 PM
thanks alot guys. I have no clue what happened to the tranny i'm guessing a possible misshift. Tranny came out of a 2000 ITR. Supposedly. the previous owner didn't even bother with fixing it he just went out and bought a new tranny.
I have enough time until next spring so this will be my winter project while i collect the parts needed. Gear-speed is on my top list. I've never felt new syncros nor LSD so this will be interesting
Old Nov 4, 2005 | 06:03 PM
mattcivic's Avatar
Default Re: (Platinum Playa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Platinum Playa &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot guys. I have no clue what happened to the tranny i'm guessing a possible misshift. Tranny came out of a 2000 ITR. Supposedly. the previous owner didn't even bother with fixing it he just went out and bought a new tranny.
I have enough time until next spring so this will be my winter project while i collect the parts needed. Gear-speed is on my top list. I've never felt new syncros nor LSD so this will be interesting </TD></TR></TABLE>
i bought an obx lsd, carbon syncros, bearings, seals, and poly shift bushings its feels awsome best tranny ever im still breaking in my motor so i havent got to grab gears hard or launch hard enough to get the feel of the lsd but im sure it will be awsome.
Old Nov 4, 2005 | 06:35 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (mattcivic)
good luck with the build!
Old Nov 5, 2005 | 01:15 PM
Flexin5's Avatar
Default Re: (00IntegrAllmotoR)
ya it was fun ripping taking that thing apart. btw: the case is mega fuxored! does anyone know, if a piece of the teeth from the busted gear was to somehow get into the LSD casing, would that cause the LSD to fail? anyway we can check to see if it's good without having to pull it all apart? TIA
Old Nov 5, 2005 | 02:42 PM
2uy
Guest
Posts: n/a
knoe where i can find a itr tranny?
Old Nov 5, 2005 | 03:01 PM
Fabfive's Avatar
Default Re: LS to ITR w/ LSD tranny...but with OH noes!!!!111 (2uy)
So youre the ******* who bought that dirt cheap ITR tranny! ******!!!!!
Old Nov 5, 2005 | 03:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Flexin5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexin5 &raquo;</TD></TR><TR><TD CLASS="quote">ya it was fun ripping taking that thing apart. btw: the case is mega fuxored! does anyone know, if a piece of the teeth from the busted gear was to somehow get into the LSD casing, would that cause the LSD to fail? anyway we can check to see if it's good without having to pull it all apart? TIA </TD></TR></TABLE>
Yes, it could cause a failure. I've seen pictures of the OBX LSD disassembled. The stock ITR unit shares the same design principles. To disassemble, you basically remove the bolts of the LSD housing to open the case. Be sure to keep track of the part locations (take pictures) and mark the housing before seperating. I wouldn't remove anything as long as you can see that there is no debris.
Old Nov 5, 2005 | 04:31 PM
I'm pretty sure the LSD is good, if you look at the pics the countershaft got the worse end of the damage. the driveshaft female end of the LSD are in great shape mint even. I've also shaked the LSD to hear anything or seen anything fall out and nothing. so i should be okay there.
Old Nov 5, 2005 | 05:07 PM
Dogginator's Avatar
Daisy... Daisy...
I'd at least spin the output shafts by hand to make sure nothing is in there. I agree that you are more than likely OK.
Old Nov 16, 2005 | 08:18 PM
Default Re: (Dogginator)
updated the first post!
Old Nov 16, 2005 | 08:49 PM
HT Black OPs
still looking good
Old Nov 16, 2005 | 10:37 PM
Flexin5's Avatar
that was a late night..but it's coming together pretty well
MShonda
Mar 6, 2012 07:02 PM
Mini_Filip
Transmission & Drivetrain
Jul 2, 2009 05:47 PM
the_23rd_letter
Aug 15, 2005 09:33 PM
not so civic
Jun 1, 2003 08:48 AM
DSF
Jan 23, 2002 02:14 PM
