Type R shock bumpstop
Old Nov 4, 2005 | 10:03 AM
Tyson's Avatar
Default Type R shock bumpstop
anyone have a picture of the stock Type R bumpstop? it looks like its different than the regular ones. #13 is type r specific.
thanks.
Old Nov 4, 2005 | 04:30 PM
.RJ's Avatar
.RJ
Default Re: Type R shock bumpstop (Tyson)
Old Nov 4, 2005 | 04:35 PM
Tyson's Avatar
Default Re: Type R shock bumpstop (.RJ)
thanks. hmm yeah, i did remember to look at your shock write up thread and saw that.. hmm.. i guess its different than normal ones ive seen on other civics. i thought you had already cut yours.
can you tell if its any firmer than other bumpstops youve seen? have you ever felt other bumpstops?
Modified by Tyson at 6:08 PM 11/4/2005
Old Nov 4, 2005 | 04:36 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">can you tell if its any firmer than other bumpstops youve seen? have you ever felt other bumpstops?</TD></TR></TABLE>
No idea... I give them a squeeze and say "yep, thats a bump stop"
Old Nov 4, 2005 | 04:42 PM
Tyson's Avatar
i guess its a bit shorter too.
Old Nov 4, 2005 | 04:53 PM
Reid's Avatar
Global Moderator
The bumpstops on my JDM ITR are black. I don't recall what color they are on my USDM ITR.
Also, the are significantly harder than non-ITR bumpstops. Also #15 in your diagram, the washer that goes on top of the bumpstop, was absent when I changed the springs on the JDM ITR. The top of the ITR bumpstop feels very hard, almost like metal. I'm wondering if there is a washer molded into the bumpstop itself, which would eliminate the need for #15.
Old Nov 4, 2005 | 04:57 PM
.RJ's Avatar
.RJ
Default Re: Type R shock bumpstop (Reid)
Right, there is no washer - the top and bottom of the shock bushing are metal and the shock bushings are much harder than other oem rubber - much better choice than poly bushings for that application.
Old Nov 4, 2005 | 04:58 PM
Tyson's Avatar
yeah, im aware of the shock top hat bushings being different. i just ordered a set of 8 today which is what prompted me to look at the bumpstop. it does indeed have a metal disc as part of the rubber bushing, which makes it much stiffer than the normal one, and no need for an extra washer i suppose.
you said your bumpstop was black? really?
anyone else want to confirm either way?
Old Nov 4, 2005 | 05:08 PM
Tyson's Avatar
here's a pic of what i thikn a standard bumpstop looks like.
btw, the CRX bumpstop looks like a barrel and nothing like this.
Padawan
11
Mar 25, 2004 12:30 PM
Dream
Aug 15, 2003 09:08 AM
disordeR
May 9, 2003 01:26 PM
MachAF
Nov 25, 2002 04:10 AM
