QUICK QUESTION--How to install C-ring on the end of the intermediate shaft.
Old Nov 4, 2005 | 09:36 AM
Si Shane's Avatar
Default QUICK QUESTION--How to install C-ring on the end of the intermediate shaft.
Thanks in advance, the clip that goes on the spline of the intermediate shaft, where it meets the drivers side axle.
Old Nov 4, 2005 | 09:37 AM
Hybrid96EK's Avatar
Default Re: QUICK QUESTION--How to install C-ring on the end of the intermediate shaft. (Si Shane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">Thanks in advance, the clip that goes on the spline of the intermediate shaft, where it meets the drivers side axle.</TD></TR></TABLE>
The clip shouldn't be removed... if you absolutely must mess with it, I would use a pair of snap ring pliers.
Old Nov 4, 2005 | 09:40 AM
Si Shane's Avatar
Default Re: QUICK QUESTION--How to install C-ring on the end of the intermediate shaft. (Hybrid93Eg)
The clip was removed and I have a brand new one from honda in my lap. I need to put it on without ruining it. Should I just take the shaft+ring to a shop and ask them to do it quickly?
I dont own snap-ring pliers
Old Nov 4, 2005 | 09:41 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">The clip was removed and I have a brand new one from honda in my lap. I need to put it on without ruining it. Should I just take the shaft+ring to a shop and ask them to do it quickly?
I dont own snap-ring pliers</TD></TR></TABLE>
Logic would tell me that would be the smart thing to do.
Old Nov 4, 2005 | 10:51 AM
Si Shane's Avatar
Ok all is well, the shop did it for free and it took no time at all. They also greased it up for me.
The axle will not go all the way into the halfshaft, there is still some play. How can I get it in there without damaging the boot?
Old Nov 4, 2005 | 10:55 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">Ok all is well, the shop did it for free and it took no time at all. They also greased it up for me.
The axle will not go all the way into the halfshaft, there is still some play. How can I get it in there without damaging the boot?</TD></TR></TABLE>
you SURE you are using the right axle? If you mix up the drivers and passenger side, it will cause this problem. Only one of the axles is splined all the way.
Nov 17, 2006 07:28 PM
Prelude-TeCh
Apr 19, 2005 11:03 PM
immalooser
Sep 2, 2004 05:29 PM
wm5holla
Oct 8, 2003 01:47 PM
Stroker
May 20, 2003 12:13 PM
