should my timing belt have 1 1/4 play in it
Old Nov 4, 2005 | 09:29 AM
streetracerof06's Avatar
Default should my timing belt have 1 1/4 play in it
i just changed my water pump on my B16a2 and after i put everything together and tightened the tensioner and every thing i noticed my timing belt has about 1 1/4 in play in it, 5/8 in either way, on the left side, the side that the belt goes straight from the left cam gear to the crank gear. the engine is out of the car because its a new engine and i decided to do the water pump before it goes in the car, so i dont know how it ran. should i get a new timing belt. the old one looks realy good but it may be stretched. thank.
Old Nov 4, 2005 | 10:27 AM
Default Re: should my timing belt have 1 1/4 play in it (streetracerof06)
bump
Old Nov 4, 2005 | 10:30 AM
Luserkid's Avatar
Did you rotate the motor a couple times (atleast 4). It takes a couple of spins for the tensioner to settle.
Old Nov 4, 2005 | 10:32 AM
IHateJDM's Avatar
Default Re: should my timing belt have 1 1/4 play in it (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Did you rotate the motor a couple times (atleast 4). It takes a couple of spins for the tensioner to settle. </TD></TR></TABLE>
exactly what I told him in his other thread about the same thing. I guess some people need to hear things a few times before they get it.
https://honda-tech.com/zerothread?id=1423736
Old Nov 4, 2005 | 10:33 AM
no i havent rotated it 4 times, should i rotate even though the tensioner is as tight as it can be, and when i get done rotating it if it is still loose should the belt be replaced. Thanks
Old Nov 4, 2005 | 10:36 AM
Luserkid's Avatar
when its all ready to be put in the motor, rotate it.
Default Re: should my timing belt have 1 1/4 play in it (IHateJDM)
sorry IhateJDM i didnt ever get that post, i posted it at school and it never showed up and i couldent check. i even logged out and then back in. My bad.
Old Nov 4, 2005 | 10:37 AM
IHateJDM's Avatar
only replace the belt if its the wrong one. if its the right length, your tensioner could be the problem, but i think you'll be fine once you've turned the motor over by hand a couple rotations.
Old Nov 4, 2005 | 10:39 AM
ok i plan on rotating it, thanks for the advice, if anyone else has something to say. please do.
down_the_hatch
Apr 28, 2011 11:41 AM
streetracerof06
Nov 4, 2005 06:49 AM
kaoss_11
Aug 9, 2005 01:55 PM
Iomega01
Aug 2, 2005 08:12 PM
SuicideSlide
Oct 15, 2004 10:06 AM
