welding pot metal?
I need to tig weld a crack in an old corvette pot metal head light bracket. What kind of filler should I be using. It has to be strong because the bracket is load bearing. Are there any tricks to this. I only have one chance and I can't screw it up. It was already sold to our customer $500 and it's the only one we have. Any help would be appreciated.
You should not attempt to weld pot metal, which has a high level of zinc in it. You have 2 choices: You can either epoxy it together, or braze it together using "alumiweld" or other eutectic hot brazing kits.
I don't think either of those are viable options. It has to be able to support the weight of the whole assembly. Why does zinc present a problem? This will probably sound stupid, but I had an idea of maybe getting a puddle going then trying to use another piece of scrap pot metal from a junk bracket that I have as filler.
Looks more like a braze. They say it's just as strong as the base metal, but I'm a little skeptical. Thanks for the lead though... Still up for suggestions.
i hate that stuff - besides being toxic as hell, it like welding a sponge -
but, if you want to throw a couple bucks at it, i use a jeweler's torch. its just a tiny oxy - acet set up. i used some adaptors to step it down from the regulator on my regular torch and i use this cat wisker size rod for brazing and dip the flux because they dont make a pre coat that gage. you have a ton of control doing it this way, just bevel it in some from the back side and get it as clean as possible before hand.
good luck
good luck
sweesiong78
Sep 1, 2013 12:19 AM
